Author Topic: Rigol DP832 Dial Sensitivity  (Read 226 times)
Offline eev_carl
« on: January 26, 2019, 01:46:07 pm »
When I adjust the voltage with the dial on the DP832, it goes up by millivolts.  Any way to make this go up and down by volts?
Thanks,
Carl
Offline JDubU
Re: Rigol DP832 Dial Sensitivity
« Reply #1 on: January 26, 2019, 03:18:53 pm »
Use the left and right arrow buttons (on each side of the dial) to select the digit that you want the dial to increment/decrement.
The following users thanked this post: eev_carl
Offline eev_carl
« Reply #2 on: January 26, 2019, 03:21:58 pm »
Perfect! thanks
