"EasySpectrum for SSA3000X - Is it useful?"
That is the question.
My answer:
Yes, it is useful. The EasySpectrum software allows you to remote operate your SSA3000X over an ethernet connection. All functionality is supported and you will see the spectrum as if looking at the physical device. So yes, definitly useful. I use EasySpectrum when I need to grab a screenshot, for example. Much quicker than using a USB disk.
Also, the 3D histogram function is nice and can be a good alternative if you don't have the advanced measurment option active on your device.
Regarding my "VMA Simple Spectrum Analyser for SSA3000X" software:
It follows a different purpose than the EasySpectrum software. In my software, I am NOT remote controlling all functionality of the SSA3000X like EasySpectrum does. I only set the spectrum parameters and read out the live spectrum. The whole data processing is done by my software.
The goal is to implement my own measurment and display functions. For instance, my software will recognize satellite transponders (or any other kind of transponders if you edit the respective setting files).
I implemented SWR measurement, as well as, bandwidth measurements.
Finally, my software offers Excel export, printing, trace overlay, amongst other functionality.
In reality it kind of feels like a different spectrum analyser, using just the hardware of the SSA3000X, if that makes any sense.
So again, I think it is worth installing the Easy Spectrum software and actually I am not sure if you still need the NI VISA drivers since the v8.2 firmware? I have not checked this (I have it installed for other devices, too). But even if you do, it is worth it. If you don't like to have it on your PC due to the services it installs, just setup a virtual machine and install it there - the interface is ethernet, so no problems here).
Regards,
Vitor
