All,
One of the parts scopes I will be working on in the near future is a 2465. On the back panel in one of the little oval slots, there is an insert that says MOD SG. From what little I have been able to find on the net, the scope has a factory modification. This mod is identified as MOD SG. What exactly is this mod? I did find a user manual for the 2445/2465 with MOD SG, and I have ordered it. What I do not know is, what exactly does this mod do? I can wait for the manual and that should explain everything, but I am impatient and figured I would ask the group if anyone knew what this mod was. I know the lower left front panel under the screen is different with the Intensity, Beam Find and Focus labels moved from above the control knobs/button to below the control knobs/button, and replaced with the words "Property of IBM". I do think that there is more to this mod than just moving/adding some words around on the panel. If anyone has any information on this mod, it would be greatly appreciated.
Thanks
Mitch
