Author Topic: military grade oven controlled crystal oscillator FTS-1000A  (Read 2524 times)
Offline Cali-SamTopic starter
just picked up what seems to be a military grade ultra stable 5 MHZ oven controlled crystal oscillator FTS-1000A . similar to this ( http://www.gigatest.net/datum/1000b-r2.pdf .
my question is.. How do i power it up? what voltage do i give it?
the connector is 9-pin d-subminiature connector. similar to the one used for RS-232 i guess. i don't know what pin is what. i really don't want to blow it up.
Offline rf-loop
Re: military grade oven controlled crystal oscillator FTS-1000A
« Reply #1 on: March 13, 2015, 09:33:22 am »
This may help or not. There may be different sub versions, so be careful. (Do some careful checks first that pin numbers match, do not blow up this treasure.)
http://ko4bb.com/dokuwiki/doku.php?id=precision_timing:fts_2000a_connector_pin-out
If all looks match then
You need power 24V and 26V.
1 GND  |  8 +26V    (electronics)
5 GND  |  7 +24V    (oven heating)
« Last Edit: March 13, 2015, 09:48:52 am by rf-loop »
I drive a LEC (low el. consumption) BEV car. Smoke exhaust pipes - go to museum. In Finland quite all electric power is made using nuclear, wind, solar and water.
Wises must compel the mad barbarians to stop their crimes against humanity. Where have the wises gone?
