Author Topic: DS1054Z front end switching noise?  (Read 2576 times)
Offline ice595Topic starter
« on: January 15, 2016, 11:11:33 pm »
So, I've got my Rigol DS1054Z a couple of days ago and hacked it to 100MHz.
As I was playing around with it, I discovered that the front end on all 4 channels seems to pick up a bit of noise.
I've disconnected all the probes and set coupling to GND and set 20MHz BW limit off.
it seems like channel 2 is "less" noisy that the others.
does anyone have this problem? ???
« Last Edit: January 15, 2016, 11:31:35 pm by ice595 »
Offline TheSteve
  • Living the Dream
Re: DS1054Z front end switching noise?
« Reply #1 on: January 15, 2016, 11:29:11 pm »
Its normal. The Rigol DS1054Z isn't perfect, but it was cheap...
VE7FM
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #3 on: January 20, 2016, 02:10:15 pm »
my ds1054z arrived today... fresh unmodded 50MHz with limitation...
1st pic: before cal
2nd pic: after cal
same setting as OP... (except 2nd pic i forgot to reset to 1X)
« Last Edit: January 20, 2016, 02:11:58 pm by Mechatrommer »
