Products => Test Equipment => Topic started by: diawollo on March 20, 2016, 08:10:50 pm
Title: Rigol DS1000Z add Signal generator mod
Post by: diawollo on March 20, 2016, 08:10:50 pm
Lets start to discuss about DS1000z conversion to  DS1000z -S. Can anyone tried to add signal generator daughter board?
Is it possible to flash  DS1000z -S firmware to DS1000z  osciloscope?
Title: Re: Rigol DS1000Z add Signal generator mod
Post by: TheSteve on March 20, 2016, 08:30:08 pm
The firmware is the same - but where are you going to get the daughterboard from?
Post by: diawollo on March 20, 2016, 08:45:32 pm
It's a little secret  :D I will reveal it someday, soon.
P.S. If the firmware is same on both DSO then why on  DS1000z there is no Signal generator icons? Maybe it will appear after inserting daughterboard?
Post by: ebastler on March 21, 2016, 12:18:40 am
Hey, you are the one who claims to have a source for the daughterboard -- you better figure it out...  :P
Seriously though: You claim to have one part of the required solution, but are not telling us.
But at the same time, you expect the forum to help you with the other part of the solution?!
Post by: bitseeker on March 21, 2016, 07:05:29 am
Ah, so you've made a daughterboard for it? Excellent! Don't leave us in suspense too long. :-/O
Post by: TheSteve on March 21, 2016, 08:39:58 am
Finding a nice way to add the front source button might be the most challenging part...
Post by: Fungus on March 21, 2016, 01:27:46 pm
Dremel...?  :-//
Post by: Mechatrommer on March 21, 2016, 02:36:24 pm
Dremel...?  :-//
no need dremel or even the cheap dremel clone. just a paper cutter knife. the hole is already there nice and square.
Post by: TheSteve on March 21, 2016, 03:34:21 pm
The hole is easy, you still a button though that hopefully doesn't look too ugly.
Post by: Mechatrommer on March 21, 2016, 03:47:57 pm
still, a paper knife with some dried silicon is the key. the rest is time and perseverance.
Post by: papousek on March 23, 2016, 06:07:43 am
Interesting!
i'm just wondering which to buy, Rigol DS1000Z or Siglent SDS1000X...
https://www.youtube.com/watch?v=_H-2ywxrbH4 (https://www.youtube.com/watch?v=_H-2ywxrbH4)
