Author Topic: Waveform update rates of HMO scopes  (Read 1228 times)
Offline pxlTopic starter
  • Country: hu
« on: March 23, 2016, 07:44:18 pm »
Hi guys, HMO owners :)
I would like to ask you to make some measurements on your scope, I plan to create a "comprehensive" table so that we could compare all existing and future HMO scopes. At this point I would need 16 values only.
The measurement -  please setup
input signal: 2.5 V peak to peak, 100 kHz square wave (e.g. the built in pattern gen/square wave is ok in newest HMO scopes)
the scope:
- one channel only
- edge trigger, AC filter
- trigger time set to zero
- please setup the trigger level to get max. waveform/s
- all measurements, special settings off
wfm/s - measure the trigger out freq (e.g. with Brymen 869, everyone has one ;))
samples/s - reported by the scope
These would be the values I am interested in at this point:
TB/Record ModeMax. WFM. Rate - wfm/s,samples/sMax. SA. Rate - wfm/s,samples/sAuto - wfm/s,samples/s
2ns143001G9001G141001G
100ns
5us
200us
I hope that I did not forget anything and all clear. Later, we could refine the prerequisites of the measurement, but for now, please measure these values. All participation will be appretiated :)
Thank you!
« Last Edit: March 23, 2016, 07:47:12 pm by pxl »
