I read in another thread that an issue with the DS1000z series is that while moving the horizontal or vertical offsets, the waveform stops updating. It only shows a frozen trace while you're moving it around until you let it sit for .5 seconds or something. This sounds like a problem the DS1052E had, and I'm wondering if they have patched the firmware so that it updates while you're changing offsets now. It's very useful for me when looking for a pattern of a semi-infrequent known event an unknown time from the trigger. Does anyone know?
Just want to check before I pull the trigger on upgrading from an 1102E to a 1000Z. Thanks!
