It's interesting that in the Rigol, you can see the counting transactions ( Channel 2 blue ) and in Keysight you see a freeze counting value Showing that only 1 waveform is acquired while on Rigol was many, I guess was 32 since you can see a transition on 5 bit
I guess you use a too long GND path, try remake with all probes GND connect to the GND pin near the 0 button or right near PIN 21, there is a better and short GND who probably will make a more nice waveform, with less inductive effect on probe
