Author Topic: Rigol DS1054z 1 wire signal capture  (Read 3788 times)
Offline scobayTopic starter
  • Country: ie
« on: October 17, 2018, 12:09:49 pm »
Hi I recently upgraded my rigol 1052e for a DS1054z I used to be able to the the Dell laptop signal ps_Id on my old scope but I am unable to capture the signal n the ds1054z. I believe this comes from within the charger from a Dallas chip using the 1 wire protocol. I dont need to decode the protocol just be able to see the signal is present for charging the battery.
I haven't got the hang of the scope yet so any pointers would be great.
Offline Fungus
Re: Rigol DS1054z 1 wire signal capture
« Reply #1 on: October 17, 2018, 01:48:50 pm »
The procedure should be the same.
What settings are you using?
The following users thanked this post: scobay
  • Country: ie
« Reply #2 on: October 17, 2018, 03:49:01 pm »
I have tried everything to no avail, I have copied the setting from this screen grab but I cannot see the signal (even on auto)
Offline StillTrying
  • Country: Broken Britain
« Reply #3 on: October 17, 2018, 04:10:26 pm »
"I have copied the setting from this screen grab but I cannot see the signal"
Does the trace at least move up to the 3.3V level, or does it stay at the 0V marker level.
Does the channel show the scopes own 1kHz 3V test.
Is the probe and scope channel on X10.
If you're using a new probe's witches hat clip they sometimes need more than expected force before they click and make contact.
Offline Fungus
« Reply #4 on: October 17, 2018, 04:33:09 pm »
This seems likely if there's no signal at all. You have to press quite hard to get the clips to click into place.
  • Country: ie
« Reply #5 on: October 17, 2018, 04:35:10 pm »
HI yes it jumps to 3.2v but no matter what I do I cannot get a signal from it
  • Country: ie
« Reply #6 on: October 17, 2018, 04:38:47 pm »
I can get the test signal and various signals from around the board , clk/data but the ps_id sigal I cannot get
Offline StillTrying
« Reply #7 on: October 17, 2018, 05:34:54 pm »
If you've got the trigger on the same channel, the trigger level at about +1.5V, and the X trigger position at the center of the screen, I can't think of much else!
Peak-detect and roll mode, to at least see if the signal is there?
Offline kcbrown
« Reply #8 on: October 17, 2018, 06:42:31 pm »
Check your triggering setup.  From the image you posted from your 1052E, it appears that you'll want edge detect triggering on the falling edge (since it appears the signal is active-low), with a 1ms holdoff.
What are all of your settings for the trigger?  A screenshot of them from your 1054Z might help clarify things.
Oh, and you probably want "normal" trigger mode for this, not "auto", so that you see only the signal.
« Last Edit: October 17, 2018, 06:45:49 pm by kcbrown »
  • Country: ie
« Reply #9 on: October 17, 2018, 08:18:44 pm »
Seems to be it only pulses when power is supplied and I cant seem to acquire the signal as its too fast and I cannot figure out how to grab it.
Offline TK
« Reply #10 on: October 17, 2018, 08:24:24 pm »
Maybe you should try trigger in NORMAL mode?
  • Country: ie
« Reply #11 on: October 17, 2018, 08:44:36 pm »
I changed the sweep to normal mode and I get this waveform
Offline TurboTom
« Reply #12 on: October 17, 2018, 09:22:13 pm »
You've also delayed the time base considerably so you actually never saw the trigger instant. Just press the "horizontal position" knob once and the trigger marker is right on-center and the triggering event should be visible.
Offline kcbrown
« Reply #13 on: October 17, 2018, 10:00:56 pm »
Good.  The reason it looks different from your 1052E is that you have the timebase set to 50us instead of 500us, and you have the vertical sensitivity set to 2v/div instead of 1v/div.  If you change those two things, you'll get something that looks similar to what you saw on your 1052E.
It won't look identical, because it appears you had your trigger set up to look for rising edges on your 1052E, but it'll be close enough (given the signal, it looks like falling edge triggering is more appropriate for this signal, which is why I suggested it in the first place).
« Last Edit: October 17, 2018, 10:02:29 pm by kcbrown »
  • Country: ie
« Reply #14 on: October 18, 2018, 01:45:47 pm »
Many thanks , I have a bit better understanding of it now. Basically I though this was a repeating signal so I was missing it as it only occurs once (When you plug in the adapter).
