I have an HP 34401A that has an issue measuring AC voltage. With voltage applied, the display freezes and does not display the actual voltage. Other measurements (DCV, resistance, continuity, etc.) seem to be read ok.
I figure something is fried inside, but I'm wondering if it's something that's easily repairable or I should just send it out for repair. The unit was last calibrated in February 2015.
