Products => Test Equipment => Topic started by: oldprogrammer on September 15, 2016, 02:28:07 am
see pics here - http://imgur.com/a/6EOxj (http://imgur.com/a/6EOxj) When I set the decode options to display data in ASCII (bottom pic with all EEEE), the bytes are shown correctly. When I set to display in Hex, byte frames are blank. Anyone run into this? Thanks!
There might not be enough space in the little box for the HEX representation. Speed up your Time/div to display fewer but wider boxes.
