Thankyou so muuch for sharing the tip in relation to the vertical center setting. This has made the situation so much better.
Unfortunately there is still a terribly inconvenient problem. If I have the option set to center, and for example have a signal of -18v in display,
I can change the vertical range from 20v to 1v div and the display stays centered on -18 as you would expect it to. However as soon as I change it to 200mv div range, the display will jump to centering on -2v. This seems like it might be a bug and it is so incredibly annoying. When you are at 200mv or less, it takes like 100+ turns of the wheel to re-center at -18v. Does anyone have a workaround or solution for this? I'd rather go back to an analog scope than have to do this all the time.
Many thanks
