Poll
How do you use, what do you think about your hacked/non hacked DS1054Z/DS1000Z series scope?
I use any of hacked serial decoding, advanced triggers, REC, MEM in the real usage scenario
19 (15.8%)
I measure the signals which require more than 50 MHz bandwidth
7 (5.8%)
Measure more than 50 MHz + use serial decoding/advanced triggers, REC, MEM in the real world scenario
29 (24.2%)
Hacked my scope but would rather trade hacked options for absence of bugs and better specs
7 (5.8%)
Have DS1000Z series scope but didn't hack it or hacked but don't use what hack offers
7 (5.8%)
Don't have DS1000Z but want to see poll results (empty vote)
51 (42.5%)
Total Members Voted: 118
Voting closed: July 21, 2016, 10:17:31 pm
Author Topic: Rigol DS1054Z/DS1000Z poll: are hacked options actually useful for you?  (Read 23504 times)
Offline wraperTopic starter
  • Country: lv
So in DS1054Z tread and earlier in other treads, there appeared a debate if people actually need/use hacked options in DS1000Z series scopes. Or if it is more like self delusion and people buy this model just because of the hackability and think they get a great deal while actually hacked options bear no real value in everyday use for them. DS1000Z also have some few serious and many minor bugs which don't get fixed in timely manner and new bugs introduced in the new firmware too (like broken RMS measurement in the latest firmware which is there for ~6 months and no fix/downgrade possible). This debate was raised because not so long tome ago appeared very interesting GDS-1054Z from GW instek which overall appears to be better in almost every way (faster waveform update rate, 1 mpts FFT, better advanced math, better analog spec and so on) and a little bit cheaper too. Also overall interesting and affordable whole GDS-1000B, GDS2000E series (more expensive, but decoding is out of the box). Absence of serious bugs makes them very attractive to. However people still insist you must get DS1054Z because it is HACKABLE and it is where the true value lies. So are those hackable options as good in your everyday use as people talk about, you decide.
P.S. This poll is about if you actually use what those hacked options offer. Not about if you like the fact of hackability.
« Last Edit: June 21, 2016, 10:34:47 pm by wraper »
Offline Fungus
You need over 50Mhz to see a 10Mhz square wave with any sort of squareness, so...  :-//
  • Country: lv
The question is do you always need that complete squareness? Also I doubt any of Arduino tinkerers can see any square wave of such frequency, maximum they will check is crystal oscillation (sine). Other MCU peripherals usually run at much slower speeds either. Also nctnico used serial decoding on GDS2204E on SPI bus with 125 MHz clock without an issue, although it looked more like sine wave.
Offline Fungus
The question is do you always need that complete squareness? Also I doubt any of Arduino tinkerers can see any square wave of such frequency...
Maybe, maybe not. Seeing a sine wave instead of a square wave is disconcerting to a newbie though.
PS: I bet 'Arduino tinkerers' do like having serial decoders and they probably don't care much about FFTs or simultaneous RMS voltage readings across multiple channels.
Offline CustomEngineerer
How come the MEM-DS1000Z (increased memory) and REC-DS1000Z (Real Time Waveform Record and Replay) options aren't listed in the voting options?
Edit: Not trying to suggest you need more voting options. The options really should just be, "I have a DS1000Z but haven't hacked. I've hacked it but get no use out of it. I've hacked it and use the options all the time."
Don't really see the point in splitting up the ones that have hacked it and gotten use out of it other than to make the other 2 options seem like a bigger percent.
Edit 2: Not voting as I don't have a DS1000Z, though do have DS2072A.
« Last Edit: June 21, 2016, 11:11:13 pm by CustomEngineerer »
Offline ebclr
Sooner we will understand , I beat the point is to blame Rigol
The following users thanked this post: luma
  • Country: lv
added REC and MEM to the first voting option.
This poll is for bottom of the end model. I have hacked DS2072 myself. The point of this poll is if those hacked options are so important as alternatives don't have them. On the other hand, alternatives in DS2000A price range have those out of the box and don't need any hacking or purchasing. Well, now I myself have bit better idea what I should have written as voting options, but don't want to break it and start voting again.
That is to see how important the bandwidth is, as it is the only difference between the differently priced models in the series.
Online ataradov
    • Personal site
I do use memory size and triggers.
I don't care about FFT, since I can dump lots of data (see memory size) to my computer and do analysis with real tools.
Alex
Offline ebastler
You forgot the "Hacked or not, my GW Instek is better anyway" option.  :palm:
Geez, where re we -- kindergarten?
The following users thanked this post: Fungus, nugglix
Offline tautech
Yep, kindergarten where we start to learn to read.
Of course I'm one of the nosy ones that just want to see the poll results, BTW wraper thanks for adding that option to the poll.  :)
Avid Rabid Hobbyist
Offline ebastler
Huh? I don't think you got my drift there...
Offline tautech
I didn't and sorry for any offence, none was intended.  :)
Avid Rabid Hobbyist
The following users thanked this post: ebastler
Offline Fungus
The "Hacked my scope but would rather trade hacked options for absence of bugs and better specs" option is wide open to interpretation as well. What exactly are "better specs"?
If the poll is really about bugs vs. hacks then the option should be: "Hacked my scope but would rather trade the upgrades for absence of bugs".
(And how severe are the bugs, really? If a bug takes 6 months for the first person to notice it then how should we rate it...?  :-// )
« Last Edit: June 22, 2016, 06:07:39 am by Fungus »
  • Country: lv
This is not true and you know it.
  • Country: lv
Edited not hacked option. Now you can vote for that also if you don't use what hack offers but also don't want to vote for option above it and think it's still the best scope for the price even without a hack.
Offline ebclr
I would like to know any serious bug on rigol, I use mine on a daily base on my work is done everyday, where are those bugs ? Are they relevant ?
Offline Fungus
The deadly serious "RMS" bug was first reported in early March: https://www.eevblog.com/forum/testgear/ds1054z-issue/
The firmware responsible for it was released in early November.
Ok, that's only 5 months, not 6. You win.
  • Country: lv
That also means they didn't fix any of the newly introduced problems with that firmware for 11 months. I thought it was a bit newer.
Offline ebclr
This bug is totally irrelevant on a scope far away to be serius
Offline alsetalokin4017
It depends on what you mean by "serious".
Do you consider having a high RMS value measurement displayed on channels with zero inputs, even grounded, a serious bug which calls into question the accuracy of all reported RMS measurment values? I do -- but then again I do (or try to do) a lot of power measurements using my scope.
Do you consider having a horizontally displaced and misscaled Math trace at 500 ns/div a serious bug? I do. Again, the ability to make certain power measurements at particular frequencies is compromised by this bug. Fortunately it only happens at the 500 ns/div timescale-- as far as I can tell.
Do you consider having _all_ Measurements stop working at random times when Math and more than 2 channels are being used, requiring a power-cycle reboot, a serious bug? I sure do; in fact this one is a major buzzkill and Rigol USA reproduced it on their scopes immediately when I reported it to them months ago.
Do you consider having a Measurement displayed with a spelling error as "Pluses" instead of "Pulses" a serious bug? No, I don't consider this one "serious", since it does not affect usability, it is just laughable -- and demonstrates a rather shoddy quality assurance process at Rigol, for them to have released such an obvious and easy-to-correct typo in their code.
Or how about the fact that the FFT display resets its scale features when switching Mode from "Memory" to "Trace" or vice-versa? Serious, or just terminally annoying?
Other bugs that I don't consider serious are the sluggish response to vertical positioning controls, and the inability of _some_ users to push a knob-button without also turning it (the secret is in how you support your hand while pushing the button, it is easy to avoid this "bug" which has even caused some users to replace their rotary encoders altogether, LOL -- if this is a "bug" it is a bug in the user, not the scope). Or the "loud" fan which in my laboratory is not audible over all the rest of the equipment fans that are constantly running-- not a serious bug (feature) at all, but many people have replaced their fans with quieter ones. Or the slow saving of screenshots to USB flashdrives -- just wait, go get a beverage or something, it's not serious just annoying. (But the occasional strange failures in filename sequencing may be serious under some circumstances).
Offline Fungus
Maybe you should chase that one up. See if they're fixing it.  :popcorn:
It may be irrelevant to you, but it has caused at least one DS1054z purchaser to regret his purchase and to seek to return his scope and get a different brand.
It's not irrelevant to me either, but I'm not going to return my scope over it. I fervently hope that Rigol will get on the ball and fix this and the other serious bugs in the next firmware update.
Oh, yes, I forgot one "feature". It is not possible to roll back to an earlier firmware version once you have installed a later one, by any process that I am aware of. This is just stupid, IMHO, and is very serious, since it is clear that firmware updates can introduce new bugs that may not be acceptable to some users.
Maybe if many other users who can duplicate this bug take the trouble to file bug reports to Rigol ..... some action will be taken.
Or maybe it's just too hard for Rigol to fix all these issues and they've simply given up, having already saturated the low-end DSO market with the DS1054z. After all... many users of the scope find nothing wrong with it, since their use of the scope is so basic that they never encounter the bugs.
BTW-- I voted this option in the Poll:
Measurement of fast rise/falltime pulses, advanced trigger options, REC and deeper memory used often. Serial decoding, not yet but will be doing so in the future.
« Last Edit: June 22, 2016, 01:47:05 pm by alsetalokin4017 »
Offline ebclr
I guess this one will have a little less bugs and better English
http://www.keysight.com/en/pcx-x205209/infiniivision-4000-x-series-oscilloscopes?nid=-32539.0&cc=US&lc=eng
Now the bug will appear on your pocket
Offline Fungus
Maybe if you told people how to "file bug reports to Rigol" it would be more productive than endless posting about it.
I'm not sure what's going on.
If I had to guess? I'd say the lead programmer at the DS1054Z division has left the company and his replacement is a prime candidate for TDWTF.
Somebody at Rigol really needs to pull their finger out.
That's certainly true
(...but not because they're idiots or anything, it's just that 99.9% of real life 'scope use is basic. It's triggering, it's looking at wiggly lines on screen - both of which the DS1054Z does admirably well)
Are the values on the channels with inputs correct? If so, it's not a serious bug, no. Most likely just a bug in the 'isAnythingConnected()" function.
Turn those channels off and the bug vanishes!
Math needs fixing, we agree on that.
OTOH what's a good response to every newbie who posts here asking if the DS1054Z is worth buying? Is it:
a) Do you need to apply math functions on multiple channels at 500ns/div? Is that a critical function to you? If so, the DS1054Z has a known issue.
Or is it:
b) OMG!!! The DS1054Z is totally bugridden!!! Don't even think of buying one, buy one of these instead. Sure the other one is big, ugly and a horrible recycled yellow/brown color. Yes, you'll have half the bandwidth, less RAM and no serial decoders. The font end's noisier because they used cheapo op-amps, the build quality's a bit lacking, the screen bezel is a bit, um, 'chunky' because they were cheap and used the case from a model with a bigger screen... but you'll totally avoid the deadly 500ns/div math bug when more than 2 channels are on!! It's sooooo worth it!!!
No. Stuff like that slips through sometimes.
Annoying.
User interface is my specialty, things like that dismay me.  :(
(yes... I do have complaints about Rigols, but none of them are to do with bugs)
There's definitely a crapness and general lack of thought in parts of the DS1054Z user interface and some things that just don't make any sense at all (like the duplication of the trigger mode settings - what a total waste of panel space and LEDs that is).
Lots of other devices do it the same way though. It seems to be an industry standard crapness, not something Rigol invented.
Yes, I've posted some very simple suggestions that would improve the UI immensely. If Rigol wants to talk? I'm happy to help out.
« Last Edit: June 22, 2016, 03:40:24 pm by Fungus »
Offline rstofer
Let's assume the 'bugs' are never going to be fixed.  It is clear that the scope is inadequate for your needs, why are you still using it?  Sell it at a discount and buy the cheaper Instek with NO bugs.  It certainly seems like a win-win situation.  You probably break even on the cost or at most take a small loss and you wind up with a bug free scope!  I can assure you, ALL of the bugs will never be eliminated.  It's the nature of digital...  Some programming is required!
Offline rstofer
And you can buy options!  For significant extra additional expense, you can probably get serial decode.  Wouldn't that be cool?
Offline Fungus
They got it all working except a couple of minor things but those things can never be fixed? Ever?  :-//
But somehow that same 'nature' doesn't apply to GW Instek?  :-// :-// :-//
Your logic makes me  :scared:
  • Country: lv
Not at all. Just connect the channels to probe compensation input and check what RMS measurement is displaying (If you have latest SP2 firmware).
It's not yellow brown, actually color of the plastic itself is exactly like Rigol. Inputs are less noisy than 1054Z. Yeah, Crapxon in rigol's PSU and hard to find a main board which were not reworked at least somewhere, are certainly better than Japanese capacitors and cleanly soldered board in instek.
Offline ebastler
Wraper, all -- while the poll is still open, I think it is time to admit that people do actually use and value the "free" options on their DS1000Z scopes. A lot. As of right now, 80% of the responses confirm that (34 out of the 43 who actually have one of these scopes).
Can we please acknowledge that, instead of drifting into the umpteenth "how bad are the bugs" discussion?
I think it is safe to assume that those who have bought the scope, and are regulars on this forum, did know what they were buying and had their reasons to buy.
  • Country: lv
What I need to admit? Who said people don't find they are useful (Have hacked DS2000 myself)? Poll is to show how important something is for certain amount of people.  Also it shows that significant amount of users have serious enough issues with it, that would give up the so valued options for "optionless" scope which works without problems.
Offline ebastler
Maybe you could admit that Rigol users are not deluded?  :palm:
Offline Fungus
Dave says otherwise:
https://www.youtube.com/watch?v=9SXZk2tsQ4g#t=2m10s
That certainly wasn't Dave's conclusion in the teardown....
https://www.youtube.com/watch?v=9SXZk2tsQ4g#t=31m20s
Rigol can't even solder?  LOL! :-DD
« Last Edit: June 22, 2016, 04:37:14 pm by Fungus »
  • Country: lv
So far 7 % don't use hacks,  13.6 % have serious enough issues that would give up on the hacked options, 79.5% use those hacked options.
Offline rstofer
First, the motivation declines as the bug list gets shorter and the bugs more obscure.  At some point development is over and it's time to move on to the next scope.
Second, it is the nature of large software projects that poking it in one place causes it to break in another place.  Kind of like pushing on a balloon.
The best Fortran programs were written after the box of cards was dropped on the floor.  It's just easier to start over.
Purportedly, the bug list is still extensive and serious.  I don't see why any advanced user would buy this thing when they could get a way better scope for a lot more money.
It only applies to Instek if you believe that they are bug-free.  I don't...  But maybe they really are!  It's pretty easy to be bug-free if your software doesn't do anything.
« Last Edit: June 22, 2016, 04:36:45 pm by rstofer »
  • Country: lv
I don't see there noise being higher than in Rigol. Then listen and read what Dave comments about this.
Seriously? Let me google that for you:
https://www.rigolna.com/tech-support/
 :palm:
Offline Fungus
Are you watching the wrong video?  :-//
https://www.youtube.com/watch?v=9SXZk2tsQ4g#t=38m40s
I'm guessing you didn't even watch it properly. You replied in less time than it takes to actually watch the video.  :-DD
Offline Fungus
Thanks for reading the numbers on the screen to us. How would we ever manage without you?
PS: Now they've changed...
  • Country: lv
I watched a few minutes, as your link includes the time, also I've seen that video before. Dave explicitly says that is not noise on the input, but how display engine works (sin(x)/x), out of 1 bit ADC reading change there appears such thing. Also if you set slower time scale, then of course waveform becomes thicker and there is nothing like that seen anymore. Now switch on your scope at similar settings and check how thin the waveform line is. But for real noise switch it on with 1 mV/div vertical scale and compare it with what is on the video at the same settings. As of the front panel color, Dave had white balance set wrong (probably auto). See how his "blue" ESD mat looks like.
About "cheap opamps", TLV274 in Rigol has 2X more of input noise voltage compared to TL074A in instek.
  • Country: lv
Well, then use your own calculator, because those figures obviously are distorted by want see results option.
Offline Fungus
Whoosh!
  • Country: lv
IMO you take this poll too close to your heart. You were who suggested it after all.
Offline ebastler
Just re-read your opening post in this thread again, and even you might realize why some people here get annoyed with you.
Very professional attitude; congrats.
Talking to yourself here?
https://www.eevblog.com/forum/testgear/new-rigol-ds1054z-oscilloscope/2332/, scroll down to reply #2332. (Sorry, don't know how to link to it directly.)
  • Country: lv
Then read my post again, there was a qoute in it BTW  :palm:
Reply #2331:
We could do a survey if you want, but... I'll bet that nobody here bought their DS1054Z thinking they were getting a 50MHz 'scope with basic triggering, 12Mb RAM no serial decoders.
And when that wish came true... shit throwing started.
« Last Edit: June 22, 2016, 07:16:48 pm by wraper »
Offline ebastler
Got me there, I stand corrected.
The survey suggestion was Fungus', but the attitude is all yours.
I'm out of here, cheers.
  • Country: lv
Example from my first DM3068. Shunt resistor and two ICs reworked, 2 wires soldered in parallel to existing tracks  :-//. One of those IC is where leakage current matters a lot and guard tracks all around, but all of those were covered with a bunch of flux residue from the rework. That meter failed within a week with a strange issue. IMO it was defective from factory but they done something and it kind of gone away. Replacement meter took hell a lot of time and effort to get (Response was "we see the defect but we think it is kinda within spec although our own DM3068 don't experience anything like that"). Filthy used replacement (didn't care much about that fact anymore) which I got in the end, don't have those bodge wires although PCB revision is the same and manufactured at almost same time. Other Rigol equipment usually is not so extreme but very often there will be a few SMD parts reworked.
Found this comment from the video rather funny.
Quote from: RandomYouTubeUser
gw instek is garbage. Got an "expensive" model back in 2008 full of bugs, 2 channels dont work most of the time., usb storage doesnt work, gnd level change when you cange ranges, tons of noise (more than other digital scopes) below 20mV range ... GARBAGE. And it was 4 chan 2Gs 200Mhz. The next time we bought a Tek, leason learned.?
Realize this is old, but all companies have their issues.
Offline System Error Message
:O i bought GW instek i hope its not noisy or buggy.
Offline bitseeker
If it is, you can start a new thread about it. Otherwise, enjoy it! :-+
Offline Fungus
There's a perfect periodic glitch on the display engine on all 4 channels?
That doesn't sound like the sort of thing I'd want in an oscilloscope. If it was Rigol you'd be screaming "bug!!!"
« Last Edit: June 23, 2016, 06:59:41 am by Fungus »
Offline ProBang2
The glitch obviously happens with 250 MHz ==> Samplerate.
Not very impressive...    :-DD
  • Country: lv
It's not a glitch. There is a one sampling point (dot of the screen) per each of that so called "glitch". It how sin(x)/x works. You can perfectly see that if set it to the dot mode (and what Dave does later).
« Last Edit: June 23, 2016, 10:33:12 am by wraper »
  • Country: lv
So how this screenshot from DS2000 is a lower noise or a tiny bit better? What we can see here is that no sin(x)/x happens at the display stage (can be seen when zooming in already captured waveform) unlike in GDS-1000B, don't forget that sampling frequency here is higher too.
« Last Edit: June 23, 2016, 09:54:54 am by wraper »
Offline ebclr
For those guys that want to see a perfect rms value on a 8 bit scope, I would like to inform that have a revolutionary measure instrument called multi-meter who work better than a scope to do that like  the fluke 87V.
I use the scope basically to see voltage x time, in real word usage the shape and timing are the keys points on a scope, specially on very low priced scopes.
Id somebody buy very low price scope to use in a metrological lab as a standard, it's clear that that this guy brain isn't fully populated by neurons cells
I use the Rigol scope totally successful for service and development on microprocessor and FPGA, and I did even know that they can display rms value, since i never needed that , because i would prefer to user a multimeter to make this kind of measure ( 100 Kzs max ).
It's amazing that the same one that point a rms measure as a "supposed serious bug" don't care about double the bandwidth, who will help in better better measures on rise / fall time. Serial decoding for "free"
For sure Rigol isn't a Keisight Tecktronics or Lecroy, but they give you all you can expect from a Chinese product, with the basics working and a lot of little bugs and hugly internal construction, same as any Chinese toy, camera , chair etc
If you wanna product's with fine details buy swiss products and Paid the tag for that, dont buy Chinese price and ask European quality this is not reality
Offline Fungus
Ummm....it's noise, honest noise. We expect that in an instrument.
The GW-Instek stuff isn't 'noise' at all, it's a perfectly regular and repeating glitch. On all 4 channels.
Most people would call that a 'problem', not noise.
« Last Edit: June 23, 2016, 11:02:02 am by Fungus »
  • Country: lv
I't not a glitch. Watch the video when Dave zooms in what it is. There is a sampling point in the center of each of those. It's how sin(x)x function displays a waveform.
« Last Edit: June 23, 2016, 11:35:59 am by wraper »
Offline Fungus
Yes, we understand that perfectly. No need to keep repeating it, thanks.
The question is: WHY, not what. Noise is random, that clearly isn't noise, it's a periodic glitch.
If it was Rigol you'd be all over that. It would be a "bug!", it would probably have a name by now.
  • Country: lv
Because when he move that waveform vertically (can be seen on the video), it changes/disappears as display has limited resolution. What you are calling being an "artifact" is lower than a noise on the rigol screen. So yeah, if there is random crap in the screen, then it is "fine" but if there is lower than than that random crap on the fixed points, depending on the waveform position on the screen, then it is "wrong"?
glad that its not noise at least. If it is repeating than maybe it can be subtracted?
If you arent satisfied with the scope at this price range perhaps you could build your own. it may take a while though  to get one of equal or better specs but you would have to consider the cost of the screen, FPGA and memory.
Is the memory on the scope is it stored in the ram or is it some on chip memory like the CPU cache or on die RAM like intel has with some of their IGPs? I know for FPGAs tend to have a lot more memory than regular CPUs. Maybe instead of using FPGA you salvage a GPU chip for the job as it is very fast at math and with very high bandwidth memory but the cooling would be hilarious.
Offline Fungus
Yes. An "artifact", at fixed points, depending on the waveform position on the screen, is wrong.
How can you possibly tell people it isn't?
Offline Fungus
If you arent satisfied with the scope at this price range...
I'm perfectly happy with my DS1054Z.
I really can't understand why I'm being told I should prefer something with half the bandwidth, less functions and much lower build quality. It makes no sense at all to me.  :-//
The following users thanked this post: ebclr
  • Country: lv
There is 256 magabyte ram connected to the FPGA/CPU ZINQ combo.
There is nothing to subtract. And it can only be a bit apparent on the flat line and is below noise level anyway, and not periodic unless you specially fine tune the waveform position on the display + fiddle with other things. Also it can be argued that there is no such a thing on rigol is a good thing, because an accuracy of sin(x)/x in it is kind of lacking. It does not try to draw proper sine waveform out of 1 bit of data what can easily seen while vertically zooming it stopped waveform (you will see rectangles). Waveform does not change while moving it on the screen vertically because there in no signal processing on the display stage unlike in instek.
Ah so the memory is basically just standard ram. Maybe some desoldering and soldering of more ram but i guess it also depends on the compute ability of the scope itself.
I do have some questions for rigol owners. Since the rigol DS1054z has ethernet and usb has anyone used the ethernet on it? What features does it have over ethernet and are you able to take the direct measurements/points from the scope to the PC and have the PC do all the memory and compute instead?
These scopes have usb and ethernet so why burden the scope with software features that could be offloaded to the PC instead? I know for standalone and portability you do need features but when more compute power is available like a PC does it get used? has anyone even talked about the included PC software?
Offline madires
  • A qualified hobbyist ;)
Exactly! I've bought a DS1054Z because of the low price, memory depth and the "free" options to supplement my 150MHz Hameg without any decoding features and only 1M memory per channel. I know the issues but I have no problem with them. There's no perfect tool for all your needs.
Offline Fungus
Yes, a lot of people use it.
All of them, I think.
Yes.
Here's the programming guide: http://www.batronix.com/pdf/Rigol/ProgrammingGuide/MSO1000Z_DS1000Z_ProgrammingGuide_EN.pdf
  • Country: lv
Data to the PC is transferred very slowly. Useful if you want to do some deeper processing with captured data, super slow and almost useless for a real time.
Offline ebclr
I guess is no more useless than your coments :-DD
Offline Fungus
You mean I can't send the full 1GSa/sec of data over Ethernet in real time?  :o
Oh, no!   :scared:
« Last Edit: June 23, 2016, 12:55:34 pm by Fungus »
  • Country: lv
Even decent USB scopes do most of the processing internally in FPGA/ASIC and only processed data is then sent to the PC for displaying it. Because otherwise it in not possible to achieve any decent waveform capture rate at all. Data stream from the 8 bit 1 GSPS ADC is 8 gigabits per second, so it's not even possible to transfer it over ethernet directly without any preprocessing.
Offline Fungus
We don't mention that around here. It curses your 'scope and brings bad luck to the owner.
But ... certain forum members have written some nice utilities. Search the forums.
Offline ebclr
The ProgrammingGuide_EN.pdf is a hidden treasure who open a wide range of applications specially  automated tests
(snip)
(snip)
http://www.teuniz.net/DSRemote/
Offline rstofer
Unfortunately, qmake seems to require a version of Qt4 or Qt5 well beyond what the Debian repositories are providing.  There is a Linux installer for 5.7 but I messed up somewhere because it simply installed it in my home directory - not entirely useful.  So, it's off to build from source but typing the configuration commands exceeds my interest in DSRemote.
It may very well be that Ubuntu has a more up-to-date version of Qt4 or Qt5.  If that's the case, the build should go quite easily.
Offline Bzzz
  • shoving atoms
    • Wan Hung Lo Electronics Blog :)
Have DS1000Z series scope but didn't hack it yet.
And if I do, it will be bandwidth. Contrary to most of the forum users here, I'd only unlock stuff that is not sold by Rigol in any way. Unlocking purchasable software features via a ...very smart random number generator is usually considered piracy.
Offline JPortici
piracy.
please, let's not discuss it here, there is/was a dedicated topic and this one has already derailed in the usual feud anyway
(rigol DID offer bandwidth upgrades in the past, or at least my seller did)
Offline bingo600
Removed my guide to build DSRemote on U14.4.
I dont want to contribute to this thread, as it's becomming seriously derailed w. piracy outbursts
/Bingo
« Last Edit: June 23, 2016, 07:25:23 pm by bingo600 »
Offline Bzzz
  • shoving atoms
For a DS1000Z model? Interesting.
Offline ebclr
Isn't considered piracy.... Is real piracy
Offline JPortici
why is it so? you can upgrade your model to a greater bandwidth by means of a software licence, why don't sell it?*
anyway, as the rigol lovers would say you should only consider this scope as the 400$ but hacked one because otherwise it is indeed a piece of garbage, compared to the other brands alternatives
and apparently rigol doesn't even care to sell upgrades anymore until it keeps its presence in the hobbyist market
Altought i am "one of the seven" i won't sell mine until i'll have another two scopes so i won't need this as a throwaway. At the end of the day i can get the job done but this doesn't mean i won't get rid of it at the first occasion
*i am assuming it was an AUTHORIZED licensce, not a "we generate the code and sell it to you -smug pepe attached to the mail-"
Offline nctnico
I don't want to start a generic argument about hacking but when it comes to the Rigol DS1054Z the hackability has turned it into (probably by far) the best selling oscilloscope ever. If Rigol took offense they could have plugged the hole in newer firmware versions a long time ago but they didn't. The same goes for the Riglol tool which allows to enable options on a large number of Rigol devices. By now Rigol could have issued a takedown notice for the website hosting the Riglol tool but they didn't. This means Rigol allows to 'hack' their equipment legally. Within many legal systems you have to take action within a certain amount of time otherwise it is assumed you allow things to happen and are OK with it (just like you can't back out of a deal you made).
Offline ebclr
50 Mhz is only for Calcuta Madre Teresa, all the bad guys here ( including myself ) will get the 100 Mhz ( in fact a little more ) with all options, due to the genius marketing idea Rigol people have
