Hello
I want to Amplitude Modulate a sinus (in channel 1) with an arbitrary waveform in burst mode from channel 2. For this, the output from channel 2 is fed back into the SDG2042 via the auxillary in/out-put on the back face. That's OK. But, at the same time, I want to start the burst in channel 2 with an external trigger and that also would have to go through the auxilliary in/out-put on the back.
I do not believe that it can take both input at the same time.
Any idea around this difficulty (I suppose I could supply trigger via the USB input but I do not know how).
Thank you for any help.
I am new to this forum and appologize if this post is not appropriate.
