Dear All,
Today I wanted to test an electronic circuit for building my own Remote control airplane ignition system. The circuit was taken out of an electronic lighter and presumably was a high voltage inverter. I connected the output leads to the DMM for 1000DC/750AC scale, and turn on the ignition circuit for a very short time (Approx. 0.2sec). I heard some buzz, probably from the piezo. Then, immediately,
, I didn´t measure any further.
Observations and problems:
- The display works as usual.
- Apparently there PCB and the components are seemingly intact. I don´t see any burnt or smelling part.
- I noticed that the DMM displays a low battery icon. it does not disappear by changing the battery.
- It measures nearly half of the resistance. I had a 100 ohm resistance and DMM displays only 1.3 ohm.
- The measured DC voltage is also reduced. Given 10V DC displays only 7V dc (at 20V scale).
- The AC Voltage (230V) appears only 20 (at 750 AC scale)
- As usual, one can hear the beep sounds while turning on and off.
- As usual, the battery polarity can be measured accurately. (+ or - terminals)
- As usual, the scale or measurement units are displayed while turning the selector dial..(dc, ac, H, Ohm, F, TTL, Cmos, ...)
- The display disappears or becomes very dim while resistance measurement at 2000Mohm
- There is a reading of -27.9 ohm at 200ohm scale while no measurement lead is connected.
- At continuity measurement there is .377V and when the leads are connected together. The display shows 0 and beeps. Beeps sign appears and low battery sign disappears. Diode sign stays at its position.
I have not tested the capacitance yet. If you have any ideas what can be damaged or any suggestions are welcomed.
Many thanks and best regards from Germany,
