Author Topic: 16 (14) Bit 250ksps 4Ch data aquisistion with PC  (Read 1060 times)
Offline luky315
  • Country: at
« on: May 15, 2016, 08:03:10 pm »
I am looking for a simple and relatively cheap solution to sample blocks of data (a few seconds long) with a C# application (on a Windows PC) for further analysis.
Is there a commercial USB based measurement system with 4 channels, a high resolution (>= 14Bit) and with a good API?
Offline Andreas
Re: 16 (14) Bit 250ksps 4Ch data aquisistion with PC
« Reply #1 on: May 15, 2016, 09:50:00 pm »
PicoScope 5442A?
Offline luky315
  • Country: at
« Reply #2 on: May 15, 2016, 10:32:25 pm »
Thanks, but >1000€ is not relatively cheap and I don't need the high sampling rate of a "real" oscilloscope.
Offline Carrington
« Reply #3 on: May 16, 2016, 12:02:12 am »
The ADALM1000 maybe? (16 bits, but 100KSPS only), around 50€.
Another possible option is the Analog Discovery. (14 bits, 100MSPS), around 250€.
My English can be pretty bad, so suggestions are welcome. ;)
Space Weather.
Lightning & Thunderstorms in Real Time.
Offline Gribo
« Reply #4 on: May 16, 2016, 07:28:50 am »
National Instruments have USB devices that might fit your requirements. The API (NI DAQ or DAQmx) is easy and very stable.
However, 250KS/s and 14 bit might be a bit expansive.
Offline rodpp
« Reply #5 on: May 16, 2016, 10:29:45 am »
From National Instruments with 14 bits there are the USB 6001 that have 20KS/s and the USB 6009 that have 48KS/s. The first for US$189 (http://sine.ni.com/nips/cds/view/p/lang/en/nid/212383) and the last US$369 (http://sine.ni.com/nips/cds/view/p/lang/en/nid/201987).
The 6002 and 6003 are 16 bits.
Offline 71cudalover
« Reply #6 on: May 17, 2016, 01:29:36 pm »
Dataq has a nice product offering starting at 30 bucks for a an entry level demonstration unit.
Sent from my SM-G860P using Tapatalk
