Author Topic: RIGOL DS2000E  (Read 12198 times)
Offline simone.pignattiTopic starter
RIGOL DS2000E
« on: September 12, 2017, 06:41:58 am »
RIGOL today has introduced two new model into the 2000 family:
DS2102E 100MHz 2ch 1GSa/sec per channel 28MPts (euro 579 + VAT) (USD 647 + TAX)
DS2202E 200MHz 2ch 1GSa/sec per channel 28MPts (euro 749 + VAT) (USD 847 + TAX)
both with free trigger and decoding RS232/UART, I2C, SPI, CAN and LIN
data sheet here: http://int.rigol.com/File/TechDoc/20170911/DS2000E_DataSheet_EN.pdf
atm Rigol link seems not working, here is mine I will remove after Rigol fix it
http://www.batterfly.com/PDF/RIGOL/DS2000E_DataSheet_EN-1.pdf
standard probes 350MHz model PVP2350
After long time I have realized the blue RIGOL logo is for the entry level models, see the different logo in the DP832 and the DL3000 non A
Maybe is the last "candy" before the real NEW oscilloscope line ??!!
« Last Edit: September 12, 2017, 06:46:41 am by simone.pignatti »
Technical Support
Offline IAmBack
Re: RIGOL DS2000E
« Reply #1 on: September 12, 2017, 07:25:16 am »
Logo "code" seems to be more complicated :)  . DP832 has blue letter, this scope has "white" letters on blue...
Online TK
Re: RIGOL DS2000E
« Reply #2 on: September 12, 2017, 01:13:35 pm »
It is double the price of the Siglent SDS1202X-E with similar features :--
Offline borjam
  • EA2EKH
Re: RIGOL DS2000E
« Reply #3 on: September 12, 2017, 01:19:58 pm »
Not exactly. If I understood well, the new DS2000E can operate *both* channels at 1 Gsps simultaneously.
Re: RIGOL DS2000E
« Reply #4 on: September 12, 2017, 01:21:43 pm »
correct and 28Mpts per channel too
Technical Support
Offline borjam
  • EA2EKH
Re: RIGOL DS2000E
« Reply #5 on: September 12, 2017, 01:29:12 pm »
Although several goodies included with the SDS1202X-E are options for the Rigol, which will increase the price considerably I imagine.
Although this is not it obviously, I am curious about Rigol's response (if any) to the "single model, single price, all you can eat" offer to hobbyists from Siglent.
Re: RIGOL DS2000E
« Reply #6 on: September 12, 2017, 01:32:16 pm »
so far there are not options, seems like Siglent SDS1202X-E all included
Technical Support
Offline borjam
  • EA2EKH
Re: RIGOL DS2000E
« Reply #7 on: September 12, 2017, 01:36:02 pm »
Oops, I stand corrected, or not?
The datasheet mentions sku numbers for options and a "bundle" option as well, which would mean that they will sell models without options?
« Last Edit: September 12, 2017, 01:38:23 pm by borjam »
Re: RIGOL DS2000E
« Reply #8 on: September 12, 2017, 01:38:19 pm »
Triggers, decoding and memory are free of charge for sure till the end of the year.
Technical Support
Offline borjam
  • EA2EKH
Re: RIGOL DS2000E
« Reply #9 on: September 12, 2017, 01:41:27 pm »
Alright, but that would mean that it's not a reaction to the 1202X-E, what I wanted to say :)
Interestingly they are reacting to the options hacking "scene". Look at the wording in their datasheet:
"28 Mpts/CH memory (offering the official option for free)" (bold mine)
Offline JDubU
Re: RIGOL DS2000E
« Reply #10 on: September 12, 2017, 05:40:58 pm »
Is there any difference between this new DS2000E series and the DS2000A series except price and the number of options pre-enabled?
Offline PartialDischarge
Re: RIGOL DS2000E
« Reply #11 on: September 12, 2017, 05:54:34 pm »
The DS2000A can go up to 300Mhz and 56Mpts, usually people buy the 70Mhz one and hack it up to 300Mhz.
Of my around 8-10 scopes (I'm not sure how many I have now) the DS2072A is the one I use mostly day to day, really like it.
Re: RIGOL DS2000E
« Reply #12 on: September 12, 2017, 05:56:27 pm »
DS2000E can go up to 1GSa/sec per channel even when using one channel only
DS2000A con go up to 2GSa/sec when using one channel only
Technical Support
Offline CustomEngineerer
Re: RIGOL DS2000E
« Reply #13 on: September 13, 2017, 04:52:15 am »
Looks like all the options are free if scope purchased before March 31, 2018.
Offline JPortici
Re: RIGOL DS2000E
« Reply #14 on: September 13, 2017, 06:01:25 am »
i'd still get the DSOX1000A + decodes for that price. Memory ain't everything
Offline nctnico
Re: RIGOL DS2000E
« Reply #15 on: September 13, 2017, 08:38:28 am »
I'm wondering what the added value is between from Rigol DS2000E compared to the Siglent 1202X-E. IIRC the Rigol DS2000 series isn't exactly free of bugs.
Re: RIGOL DS2000E
« Reply #16 on: September 13, 2017, 08:54:47 am »
Looking at the specs I would say the sampling rate and the memory. Looking at the applications we have provided several DS2000A to the industry into automatic test equipment where the good sensitivity and the strong shielding are very much appreciated. So far we haven't see the SDS1202X-E on the same environment so it is difficult to say.
Technical Support
Offline David Hess
  • DavidH
Re: RIGOL DS2000E
« Reply #17 on: September 13, 2017, 09:21:46 am »
How do they get 500 picosecond peak detection out of a sample rate of 1 GS/s and 200 MHz of bandwidth?
Re: RIGOL DS2000E
« Reply #18 on: September 13, 2017, 12:05:53 pm »
I think it is a typing mistake, pretty sure it is 1ns.
We have informed RIGOL which will reply or modify the PDF.
Technical Support
Re: RIGOL DS2000E
« Reply #19 on: September 13, 2017, 12:36:53 pm »
Here are some images taken from the 100Mhz and 200MHz with and without dots interpolation
5ns 1GSa/sec 28Mpts
Technical Support
Offline egonotto
Re: RIGOL DS2000E
« Reply #20 on: September 13, 2017, 03:16:21 pm »
Hello,
is the 500 ?V/div true or is it only a digital zoom as in the DS2072?
Best regards
egonotto
Offline David Hess
  • DavidH
Re: RIGOL DS2000E
« Reply #21 on: September 13, 2017, 03:51:27 pm »
From the datasheet:
Note[3]: 500 ?V/div is a magnification of 1 mV/div. When calculating the DC Gain Accuracy, the full scale should be considered as 8 mV (calculated based on 1 mV/div).
Offline dupreezarmand
  • Healty disregard for the impossible
Re: RIGOL DS2000E
« Reply #22 on: October 05, 2017, 03:57:03 pm »
After a 5 day struggle to get this thing through customs it is finally here. Will put it through its paces the weekend. Bought the 100 MHz version for $582.30 including shipping from arrow.com, granted I did get a 10% discount.
Re: RIGOL DS2000E
« Reply #23 on: October 05, 2017, 09:36:16 pm »
All the options are not for free on mine out of the box. Will contact Rigol and see what they say.
Re: RIGOL DS2000E
« Reply #24 on: October 06, 2017, 03:12:25 pm »
Interesting...we got our units in stock yesterday, but since I'm traveling I couldn't check...
I'll power on one unit on Monday to double check
Technical Support
