Author Topic: Rigol DS2072 - different memory depth options Ch1 vs Ch2  (Read 907 times)
Offline Circlotron
« on: February 22, 2016, 09:37:56 pm »
Was looking at the scope tonight and I noticed that Ch2 has memory depth options of 14K, 140K, 1.4M etc but CH1 has only 7K, 70K, 700K etc like as if Ch2 was on as well when the mem depth is shared. Is this a bug? I don't think it always did this but not sure. See pics.
Offline TomThomas
Re: Rigol DS2072 - different memory depth options Ch1 vs Ch2
« Reply #1 on: February 22, 2016, 09:56:52 pm »
Hi
Your Trigger Setting is the key... You Show CH1 but Trigger on CH2... hence Ch2 Needs resource and you share ADC and MEM between the two channels.
Try to set the Trigger on CH1 and you should again see 14k, 140k...
Right?
Thomas
Offline Circlotron
« Reply #2 on: February 22, 2016, 10:31:04 pm »
TomThomas you are so right!
« Last Edit: February 22, 2016, 10:33:41 pm by Circlotron »
