Author Topic: Rigol DS2072 - screen persistence ~4 sec on 20 sec range.  (Read 675 times)
Offline Circlotron
« on: August 07, 2017, 11:33:35 pm »
As the title says, only about 4 seconds persistence when the setting is 20 sec. Actual persistence is shorter on the lower ranges but i didn't check the actual values. Mem depth is set to 14K. Scope has latest firmware and runs fine otherwise. Does anyone else have the same problem?
Offline pantelei4
  • Country: ua
Re: Rigol DS2072 - screen persistence ~4 sec on 20 sec range.
« Reply #1 on: August 08, 2017, 12:36:58 am »
As the title says, only about 4 seconds persistence when the setting is 20 sec.  Does anyone else have the same problem?
Yes.
Offline TurboTom
« Reply #2 on: August 08, 2017, 10:23:35 am »
My source (unfortunately  ;) ) doesn't "feature" as much jitter as yours (tried with a delay of 20ms) but I found the same discrepancy between set and actual persitance. So I guess I can confirm your findings on an MSO2072-S ("improved" to 300MHz). Seems to be a bug in the DS2000 F/W. But at least for my applications, that's not a serious one...  :).
Cheers, Thomas
Offline David Hess
  • DavidH
« Reply #3 on: August 09, 2017, 02:38:28 am »
Apparently it is a common problem for persistence on DSOs to have little to nothing to do with time.  They all seem to base persistence on the number of triggers with the time calibration applying only when the holdoff time (time between triggers whether you have a holdoff control or not) is low in comparison.
