Hey everyone, I recently bought a DS4024 directly from Rigol with the serial decode option and the 350 MHz bandwidth upgrade. Everything seems to work fine except for an issue with adjusting the vertical position of a trace. When trying to move a trace up or down on the screen of the scope, often times the trace will just jump several divisions, or off the screen entirely. For instance, say I'm trying to look at some SPI signals, and I want to adjust the traces so I can see the SCLK, MISO, and CS all at the same time. I'll move the traces up or down to try to get them in position, but as I'm moving a trace it just keeps jumping, even when adjusting very (VERY) slowly. This is extremely frustrating, and it makes an otherwise great scope difficult to use.
I know I've seen people talk about slow vertical position, and other issues having to do with the trace moving up or down while adjusting V/div, but this is a separate issue. Has anyone else seen this behavior?
