How does one uninstall the options on the DSA815-TG? SCPI seems to be working OK but I have tried SYSTEM:OPTION:UNINSTALL but doesn't work. Is there a known good procedure?
Here is the oddball behavior...
1. The keys are unresponsive - except - if enter the decimal/hash key first then try other keys like bw/det, system, meas, tg, etc they work for a short period of time then become unresponsive again. For this short time, menus, etc work as normal, but after the timeout, they stop working with the exception in the case of multi-page menus, one can toggle through the pages with the down arrow key at the bottom of the column.
2. Hold down the freq button and turn the knob, center frequency will change. In some cases, the keys once again become responsive as above.
3. Regardless of the setting, after a short while (longer than keypress enable) the settings go back to factory default, i.e. 750 MHz center frequency, full span.
Was able to do keyboard test, all keys test OK.
Most likely needs firmware reinstall. First I'd like to uninstall the extra options to see if the problem was caused when the trial options expired (?). Otherwise, does anybody have access to the firmware update files and the method to install them at boot time?
Thanks
