Author Topic: RIGOL DSA815TG firmware upgrade  (Read 2031 times)
Offline Robbydot
« on: December 04, 2015, 03:05:40 pm »
Hi Group,
Apologies in advance as I know this subject has been greatly discussed in the past .....  I have researched the threads and I am after some confirmation regarding the bootloader versus firmware issue for the DSA815TG.
I have an older Rigol DSA815TG  ( built around 11/1/2013 ) with the 00.01.02 version of the boot loader.
At the moment I am running 00.01.07 version of the firmware which I upgraded early last year from version 00.01.05.
Main board version is 00.04
Digital board FPGA is 00.05
All options installed as well.
From what I have read I should be able to upgrade to the new 00.01.15 firmware without losing any of the options ? The problem I believe is if the bootloader is version 00.01.04 or later, this is what causes issues...
Am I correct ? I would hate to lose the options for a few gains in the operation,
Thanks for your help everyone, any thoughts would be appreciated,
Cheers,
Rob.
Offline gm0otb
Re: RIGOL DSA815TG firmware upgrade
« Reply #1 on: December 05, 2015, 11:56:19 pm »
Hi Rob,
From my understanding from reading the threads you will not lose any of your installed options by upgrading to the new firmware.
Ray.
Offline Robbydot
« Reply #2 on: December 08, 2015, 12:27:39 pm »
Cheers, Thanks very much Ray  :-)
Offline Robbydot
« Reply #3 on: January 18, 2016, 10:13:43 am »
Hello again everyone,
Just for some information I got the firmware up to ver 14 without problems..  Ver 15 made the speccy throw an "I.F." error so I rolled back to 14 and everything seems to be working fine,
Cheers Everyone,
Rob.
