After a few hours, functionally all continues to be well. Real signal-based testing will probably have to wait until tomorrow.
However, during the burn-in, the 4024A has gotten just a bit noisier. The main fan is still just a breath of air, but now there's an additional slight "ticking" sound that reminds me of a CPU fan. I wonder if there's a second internal fan mounted to a heat sink.
I powered it down, let it cool for a couple of hours, and then restarted it to see if this possible internal fan is thermally switched and would be silent again for a while. No luck - the sound appears to be permanent now. Again, it's not awful, but since there's been something of a ruckus about fan noise level on these units I'm paying close attention. Interesting that the noise wasn't there at first, but now appears permanent.
I listened carefully, thinking it might be a label that's come loose internally and ticking the main fan's blades or fluttering around in its airstream (I've seen that in the past). But it definitely doesn't sound like that. It sounds like a heat-sink-mounted CPU fan at low RPM's.
More details as I learn them.
EDIT: Couldn't stand it, had to know if it was a secondary fan. So I powered up the unit with the main fan stalled out for a few seconds. Result: The unit is absolutely dead silent. Booted fine, so there's no fan sensor that holds off until the fan can spin up. This means the little ticking sound is associated with the main (and I believe only) fan. There's also now a low frequency tone, sounds like about 120 Hz. It
might have been there before, but I really don't think so. Sitting across the room from it, all I hear is the slight air noise; the tone/buzz is the dominant sound when you're sitting right in front of it.
So I guess the biggest value of the early burn-in is to get the fan settled into whatever will be its normal operating mode!
