Do other scopes allow the trigger to be anchored (e.g. to the left or right edge of the screen) when changing timebase?
It a pain to keep adjusting the trigger position all the time.
Straight from the MSO/DS2000A User's Guide:
Horizontal Reference
Horizontal reference is the reference position according to which the screen
waveform is expanded or compressed horizontally when adjusting HORIZONTAL
SCALE. In Y-T mode and the delayed sweep is disabled, press MENU HorRef
in the horizontal control area (HORIZONTAL) at the front panel to select the desired
reference mode and the default is "Center".
Note: This function is not available in X-Y mode and Roll mode as well as in Y-T mode
when the delayed sweep is enabled.
1.
Center
When changing the horizontal time base, the waveform is expanded or
compressed horizontally around the center of the screen.
2.
Trig Pos
compressed horizontally around the trigger point.
3.
User
compressed horizontally around the user-defined reference position.
