Thanks, Fungus. As for b) - it's a hobby, I'm nowhere near professional application, so "need" is not really the word I'd be using...
I'm a bit reluctant to consider scopes that require an external computer - for a number of reasons. At the moment I only have a Raspi permanently installed in my workshop - enough to lookup datasheets and upload code to an arduino, but nothing more. I don't want to leave one of my more powerful systems in the area because it's not a pure electronics workshop - things do get dirty from time to time. Setting up a laptop with power brick and an external scope and packing things back up all the time just seemed a lot less convenient...
The second issue is long-term support. If Rigol or any other software manufacturer stopped releasing scope firmware upgrades, the scopes would still keep working the way they were. For host-based systems these days, pretty much constant software updates are required to keep up with the "improvements" that Microsoft, Apple or even the Linux community come up with (already got that issue with some of my audio devices). I'd rather spend a little more on an integrated device that I can pull off the shelf in 5 or 10 years time, turn on and It Just Works[tm] than save a little money now and end up with an expensive brick if the manufacturer goes belly-up or decides to drop support in favor of a New And Improved product.
However, nothing's been decided yet - thanks for the heads-up, I might look into these options as well.
