Author Topic: Rigol MSO1104: Hide Channel When Using Math?  (Read 193 times)
Offline eev_carl
« on: July 26, 2018, 12:46:04 am »
I found an EEVBlog post that says you can't hide a channel, say CH1, that's involved in a MATH operation.  It was from 2015 and I was wondering if this may have been added since.
Thanks,
Carl
Offline hexreader
Re: Rigol MSO1104: Hide Channel When Using Math?
« Reply #1 on: July 26, 2018, 01:00:17 am »
As far as I can tell, there is no "hide" option for Channel display, only an "off" option, which kills the signal completely, making math with the channel meaningless.
Moving the signal to top or bottom of screen reduces the display to a single line, which seems to be closest I can get to hiding the signal.
My scope was bought December 2016, but I do not think there has been any update since.
« Last Edit: July 26, 2018, 01:21:03 am by hexreader »
The following users thanked this post: eev_carl
Online Fungus
« Reply #2 on: July 26, 2018, 02:15:00 am »
I think math works with the 'on-screen' data so that isn't really an option.
« Last Edit: July 26, 2018, 02:21:55 am by Fungus »
Offline hexreader
« Reply #3 on: July 26, 2018, 03:02:45 am »
If you push the signals just a "little" way off screen, the math function seems to work, but push "too far" and the math display becomes inaccurate.
Trouble is - how would anyone know they have gone "too far" when the signal is not visible?
Sensibly, I guess it is best to keep all signals fully visible in order to have confidence that the processing will be done correctly.
I think this principle applies to the other measurement functions too. If it is not visible, don't count on the scope giving a correct result.
