Excellent video, Dave. Thanks!
A few years ago Dave reviewed a GW Instek oscilloscope that, just like this one, was functionally sound and capable but people focused on its looks. As I said then: if buttons, fonts and looks are the major criticism, then Rigol should be quite proud with their product. I see a lot of details and button/menu organization that are quite similar to my DS4000, thus it is possible they want to maintain this familiarity intact (and yes, I also find a bit odd on my DS4014 the trigger "Mode" have a specialized button).
It seemed a quite capable device with reasonable lag (keysight's are another league, but they carry other limitations by using their old ASIC) but there were not many details on this quick first impressions to make a definitive call on that. Rigol is most probably placing this product to replace both the DS4000 and DS6000 lines.
The touch interface seemed quite responsive and reasonably thought (the virtual keypad saves a ton of front fascia realstate, although it is not as nice as a real one) and I see that the buttons surrounding the screen are a great welcome addition if I am not willing to use the screen. Unfortunately Dave forgot to test the touch trigger capability. For a first implementation, that is not bad.
I see a fail in acknowledging the USB pendrive. It seems that it is running some sort of Windows judging by the C:\ drive selection, thus I don't know how the pendrive was formatted or if it is a true OS or hardware fail.
Basic memory is quite similar to the DS4000, which comes with 140Mpts default, as well as the probe auto-detection and the digital interface connector - a plus in my opinion.The true test would be to use all that with decoders, where the DS4000 fails to do well on the larger time/div settings or delayed trigger. Another excellent test would be specialized triggers (which are limited on the DS4000) and pattern searchability (non-existing on DS4000). However, the flexibility of the LA interface and its digital and analog arrangements seems well put together.
Other than that, it is always a matter of price versus performance. A hefty $2.7k for a 100MHz version seems somewhat high (similar to what a DS4014 cost at release time), but with option bundling that may start to make sense when compared to other manufacturers. Obviously that, if the Riglol works, then this becomes unbeatable.
