Hello,The (old) ut-61e has min and max values. The value read is a very fast transient, not the average over a period (0.5s). I read about 20A or 30A when charging a 4700 µF capacitor with a laptop-type power supply (36V - 4A).
The 250us capture time is the same as with the much more expensive Flukes with min/max.
Quote from: Adam Baum on February 06, 2024, 11:46:42 pmThe 250us capture time is the same as with the much more expensive Flukes with min/max.Where did you find this spec? I can't find it in the Uni-T UT61+ data sheet or user manual.
