Products => Test Equipment => Topic started by: gmebey on June 29, 2017, 02:28:10 am
I finally had some time to take a shot at unlocking my MSO1104Z-PLUS scope.
The memory dump went well, thanks for all the post out there about using the JTAG port to dump the memory.
However when I when to use rigup to view the commands I ran into an issue, and got the following error:
gerald@gerald-Vostro-200:~/rigup-0.4.1$ ./rigup
rigup: src/encode.c:20: EncodeSignature: Assertion `sig <= 0x0fffffffffffffff' failed.
Aborted (core dumped)
My scope info:
1) The header was NOT loaded, and I had to add it.
Model: MSO1104Z-S
S/N: DS1ZD1819xxxxx
Firmware: 00.04.03.SP2
Hardware: 6.1.4
A couple questions:
1) Where can I get a complete install for rigup, I'm running Ubuntu 14.04.
2) An easier option is if someone would crack the Memory Dump file for me.
Thanks,
Gerald
Update:
After some research I found out that the error was related to an issue with the MakeFile.
Error in MakeFile on line 8
Original is "LDFLAGS := -O2 -Wl,-dead_strip"
Change to "LDFLAGS := -O2"
serendipity make a comment in a post about a bad configuration in the MakeFile. See Post (https://www.eevblog.com/forum/testgear/you-can%27t-unlock-a-mso1000z-series-scope-without-a-memory-dump-and-other-lessons/)
