Hello,
I bought the osciloscope of the subject and it came with a decode license for I2C bus. Does any body knows how can I introduce the license?
Regards
Have you license key? Have you aktivated decode functions with key or are they already activated by seller?
As @tautech told when I was writing status can see on system display.
If you have not license yet (typically it do not come with scope - exept if purchased from me because I care also this for customer for avoid any extra hassle customer side. Also some other seller may do this but I believe there is not so many.
So, priority is this if you do not have license key yet.
1. Open scope information display.
There is scope ID. Copy it exactly as it is.
Send this and your scope serial number to seller and ask he arrange license key.
2. In case that seller do not help you then this other road:
Contact directly Siglent.
Send document about purchase (date and seller or even better invoice copy)
Serial number
Scope ID
There in Siglent they can generate this license key.
(this is because ID is needed and this can get only after scope is running)
Only together with ID and Serial there is possible to generate license key. So, if Seller did not run scope he also can not get key from Siglent.
