Author Topic: Siglent SDS1000Cxx series - BW upgradable via license?  (Read 1182 times)
Online tv84Topic starter
  • Country: pt
« on: June 20, 2018, 04:16:16 pm »
Can the Siglent SDS1000Cxx several series be upgraded via the GUI with a license?
SDS1000C Series,
SDS1000CE Series,
SDS1000CM Series,
SDS1000CN Series,
SDS1000D Series,
SDS1000CF Series,
SDS1000CFL Series.
Options or bandwidth?
Offline rf-loop
Re: Siglent SDS1000Cxx series - BW upgradable via license?
« Reply #1 on: June 20, 2018, 05:03:36 pm »
SDS1000C Series,
SDS1000CE Series,
SDS1000CM Series,
SDS1000CN Series,
SDS1000D Series,
SDS1000CF Series,
SDS1000CFL Series.
NA
I drive a LEC (low el. consumption) BEV car. Smoke exhaust pipes - go to museum. In Finland quite all electric power is made using nuclear, wind, solar and water.
Wises must compel the mad barbarians to stop their crimes against humanity. Where have the wises gone?
  • Country: pt
« Reply #2 on: June 20, 2018, 08:08:18 pm »
NA
Assuming that you are meaning "Not Applicable", I ask then about the + Models, namely DL+ and CML+?
I'm pretty sure they have a "manual_input_license" and I may be able to help anyone who wants to upgrade his oldie, if the option is visible. If not visible, with a little additional effort...
Offline tautech
« Reply #3 on: June 20, 2018, 09:35:35 pm »
Pre Plus models only had I/O's of USB and IIRC RS-232 so Telnet'ing into them would be difficult.
Only the newer DL+, CNL+, CML+ and CML models have LAN connectivity.
Anything before these would require some padded/tweaked USB script.
Avid Rabid Hobbyist
