Author Topic: Siglent SPD3303D review  (Read 110672 times)
Offline jimjam
Re: Siglent SPD3303D review
« Reply #50 on: June 24, 2014, 06:22:08 am »
What and where did you get it from?
Offline ScottyAU
    • ScottyAU
« Reply #51 on: June 24, 2014, 06:24:52 am »
« Last Edit: June 24, 2014, 06:29:33 am by ScottyAU »
Offline ScottyAU
    • ScottyAU
« Reply #52 on: June 24, 2014, 06:36:31 am »
Triotest heard back from Siglent - they said they fixed the issue in December.
Triotest assure me the current stock will include this fix!
Scotty
Offline TRIO Test and Measurement
« Reply #53 on: June 24, 2014, 07:04:24 am »
Hi folks, as Australia's sole Siglent authorised distributor, I'd like to set some minds at ease.  We have received quite a few emails asking if our stock of SPD3303D is the latest version and has this voltage-transient bug fixed.  Siglent has confirmed in writing to us that it is fixed in all our current stock.
We have stock as of today of all three of the PSU's in this family.   Links are here and includes the new SPD3303C for those that don't need the graphical display on the "D" model.
http://www.triotest.com.au/shop/en/search?controller=search&orderby=position&orderway=desc&search_query=siglent+spd&submit_search=Search
Check-out the new SPD3303C.  It is great value.
http://www.triotest.com.au/shop/en/dc-bench-supplies/3448-siglent-spd3303c-195w-dc-power-supply-30v-3a-x-2-25v33v5v3a-x-1-10mv-step.html
Also, if anyone wants a bargain oscilloscope, we are clearing-out the standard screen size  150MHz   SDS1152CM for just $395.00 (+gst for Aussies). These are new with full a Siglent 3 year warranty supported in ANZ by us.
http://www.triotest.com.au/shop/en/siglent/2952-siglent-digital-storage-oscilloscope-150-mhz-bandwith-2-channel.html
Cheers!
Offline ScottyAU
    • ScottyAU
« Reply #54 on: June 24, 2014, 07:06:32 am »
Really appreciate the reply TRIO Test - thanks very much!
Offline Siglent
  • Country: cn
  • SIGLENT
    • SIGLENT TECHNOLOGIES
« Reply #55 on: June 24, 2014, 08:30:26 am »
As early as last year, we have fixed this problem, please rest assured purchase.
The Best Value in Electronic Test & Measurement
Offline FrankBussTopic starter
    • Frank Buss
« Reply #56 on: June 24, 2014, 09:36:08 am »
Thanks. In which hardware version was it fixed, if someone wants to verify it? When I click on the version button on my device, it shows "hardware version V1.1".
Offline Siglent
  • Country: cn
  • SIGLENT
« Reply #57 on: June 24, 2014, 09:57:26 am »
the hardware is still V1.1, but we have corrected the mother board version.  the Prior version is SDY8.007.038D, now it has been modified to SDY8.007.038E ( as the figure showed)
Offline ScottyAU
    • ScottyAU
« Reply #58 on: June 26, 2014, 11:32:13 am »
My Siglent arrived today.  Bit hesitant to open it up just yet to check the board  ;) Display says Software 1.01.01.01.06 Hardware V1.1
I've hooked it up to the scope and done a few tests (screens below).  All tests done on the 3rd connector set to 5v with a load resistor across the 3rd output.
1) Cold power on
2) Shorting the 3rd connector
3) Removing the short on the 3rd connector
Be interested in peoples thoughts...
« Last Edit: June 26, 2014, 11:35:00 am by ScottyAU »
Offline jimjam
« Reply #59 on: June 26, 2014, 11:43:24 am »
Is that a 1V - 1.5V spike on power on?
Offline ScottyAU
    • ScottyAU
« Reply #60 on: June 26, 2014, 11:47:31 am »
Unless i'm doing it wrong (which is entirely possible) - yep!
Offline jimjam
« Reply #61 on: June 26, 2014, 11:55:50 am »
So much for that.... :(
I guess it's still better than Rigol DP832:
https://www.eevblog.com/forum/testgear/found-bug-in-rigols-dp832/msg348106/#msg348106
« Last Edit: June 26, 2014, 12:07:01 pm by jimjam »
Offline ScottyAU
    • ScottyAU
« Reply #62 on: June 26, 2014, 12:20:02 pm »
That's only on a  cold boot - turning the whole supply on.
The channel on/off does't spike.
Shorting the output does a little.
Frank i'd be interested in your thoughts mate if you read this - or Siglent.
    • Frank Buss
« Reply #63 on: June 26, 2014, 12:34:27 pm »
The 1 V overshoot after the short is more than twice as much as I measured, as you can see here: https://www.eevblog.com/forum/testgear/siglent-spd3303d-review/msg299246/#msg299246 Still better than without the fix, which had 7 V overshoots (so up to 12 V), so I guess you have a new version. I wouldn't care about it, it is below absolute maximum limits of nearly all attached 5 V electronics, like old TTL ICs, or an Arduino.
Can you compare it with ch1 and ch2? If there are no overshoots, you can be sure that it is not your measurement setup, like ground loop, impedance mismatch (but this is unlikely with 1 ms per division), to long cables etc.
But it is strange that you have some voltage on cold power on, I don't see this on my patched device.
Offline nowlan
« Reply #64 on: June 26, 2014, 12:34:57 pm »
would 1-1.5v kill anything though?
Offline ScottyAU
    • ScottyAU
« Reply #65 on: June 26, 2014, 12:50:39 pm »
Thanks for the feedback Frank.
I can confirm there is no overshoot on channel 1 or 2 (just tested).
I'm happy :)
    • Frank Buss
« Reply #66 on: June 26, 2014, 01:07:14 pm »
For example the datasheet of the ATmega128A says 6 V absolute maximum rating for operating voltage, but the chip doesn't know the datasheet :) and I'm sure it doesn't matter much if there is a short milliseconds long overshoot to 6.5 V. Once for a PIC I swapped Vcc/GND on a breadboard, wondering why it got really hot, and the chip survived it. A random datasheet for a 74LS00 says 7 V for supply voltage as its absolute maximum rating.
But I would suggest to connect your sensitive circuits only to one of the current limited channels anyway, and use channel 3 just for more robust things, like a fan.
Offline ducatistou
« Reply #67 on: August 15, 2014, 01:42:51 pm »
Happy to join you for my first post on EEVBLOG, my favourite electronics blog and Youtube chanel.
I'm a french electronics and radio listener amateur, so excuse my approximative english !
I have an issue with my new PSU Siglent SPD3303D. Since i have installed the PSU in my radio shack, i have some RF perturbations in my RTL2838 SDR Radio with SDR-Radio V2.2 console
It's a brand new SPD3303D with last firmware and hardware I suppose because I don't have overshoot at turn on or <1 V
The PSU is well grounded, the RTL dongle is very far from the PSU (more than 10 meters) in an other room, but the PSU is not so far from the antenna with a HF LNA, 4 m high, and 15m of low loss cable to the RTL dongle
When the PSU is on and output chanels off, everything is ok
When I turn on a chanel I have a cyclic perturbation and when I turn on the 2 chanels I can hear the same perturbation at half frequency than the previous one. These interferences appear on single, serial or parallel mode
You can see the waterfall screenshots and the audio files here http://1drv.ms/1t2OKzL
I'll try to contact the support supply
The output signal on scope is not so bad with very few interferences in digital mode
Thank you if you have any suggestions
BR
Eric
« Last Edit: August 15, 2014, 01:57:11 pm by ducatistou »
    • Frank Buss
« Reply #68 on: August 15, 2014, 02:18:01 pm »
That's interesting, because it is a linear power supply and not a switched-mode. Maybe it is some noice from the CPU board? I can't see the frequencies, but looks very regular, like the harmonics of the CPU clock.
Do you see these interferences with cables on the DC output connected or with no cables, too? If it is with cables, maybe you can fix it by adding some ferrite beads to the output, which might need some PCB scratching and soldering. If it is without cables, it might need some serious rework, like shielding the logic board, or maybe it injects noise in the mains input, because of insufficient filtering.
Offline ducatistou
« Reply #69 on: August 15, 2014, 06:19:02 pm »
Thank you for your reply
Siglent EU support has sent my request to their engineers, fast support answer ! Wait now for engineers answer  ::)
I can see interferences with or without cables on DC output, may be a little bit stronger with cables.
Here is an exemple with SDRSharp near 120 Mhz where I guess the interferences stronger
I plugged the PSU on a Shaffner main filter with no difference, but it is a more a common than a differential RF filter
I also think it comes from the CPU board, but why only when an output is on ???   :-//
PS : this is an exemple without LNA, direct antenna (external discon) on RTL dongle
« Last Edit: August 15, 2014, 06:23:21 pm by ducatistou »
Offline ducatistou
« Reply #70 on: August 15, 2014, 07:40:50 pm »
I made an other test :
I put the Siglent PSU near and very close to the RTL dongle and computer and surprisingly i noticed no interferences ! The dongle is shielded in a little PCB box
I put back the PSU in the shack far from tuner and interferences went back thru antenna and/or coax i suppose
Unfortunatly ... i use the PSU in the shack not in the radio room, then i can't power the LNA with the Siglent !!  :--
    • Frank Buss
« Reply #71 on: August 15, 2014, 08:05:33 pm »
Looks like it is related to how near it is to the antenna. But is there a reason why you are using a EUR 300 lab power supply to power a LNA? There are much cheaper linear power supplies without any microcontroller.
Offline ducatistou
« Reply #72 on: August 15, 2014, 08:34:53 pm »
 ;) thank goodness, it's not for the LNA ! But as it is on for my electronics projects and hacks it could do so ... but not. One of my old free homemade power does obviously better ... :-+ and i have to switch it off when i'm listening SDR. I like this PSU for what it can do, design and accuracy, but as you say for $300 i didn't expect such annoying issue in HF domain, hope it will not interfere in my next radio projects
Offline ducatistou
« Reply #73 on: August 18, 2014, 06:59:02 am »
Here is the Siglent's engineer answer :
"Hi Eric,
I don’t know much about the RF perturbations, So I cannot understand it well.
One explanation is because there is a feedback circuit which produces crosstalk while you opened the output channels.
If you have any doubt, please feedback
Offline artelse
« Reply #74 on: November 07, 2014, 10:55:52 pm »
Have been on the lookout for a new PSU and this Siglent catched my eye. What I am wondering about, is there a real benefit to have an LCD screen on the device instead of just a nice LED panel like on the SPD3301C version?
Thanks!
