Is the 2000-series really faster drawing on the screen with same settings?
Yes and no. Mostly yes.
Highest wfm/s speed for SDS2k(X) is 140kwfm/s. Highest speed 60kwfm/s with same settings.
But fastest speed exist with different t/div setting. SDS2k(X) highest speed is using 5ns/div and SDS1kX max speed exist with 50ns/div. There is more or less differencies if look different settings combinations but mostly SDS2k(X) is faster than SDS1kX. With some settings difference is marginal. Of course if we set 50ms/div and there is 750ms capture lenght in both. In this case of course difference is very minimal if any.
I just noticed an interesting thing browsing the brochures. For 1000-series, the highest sensitivity level listed is 500 uV/div, whereas for the 2000-series it is only 1 mV/div. This must be a mistake, right?
This is not mistake. SDS2k(X) do not have 500uV/div sensitivity and SDS1kX have and it is not digital vertical zoom, it is real.
Also in this forum you may find some tests etc.
Also, would like to know how the enhanced resolution (eres) works with the latest firmware, how does it affect the update rates etc.
It slows wafm/s speed lot of. If I say "typical" (both models) is that with ERES wfm/s speed is always <25wfm/s and mostly something roughly like 10wfm/s. Also, maximum acquisition lenght using ERES is 14k. Eres is more hard process than "High-Res" in many scopes what use simple box car average.
And lastly, the FFT-mode, is it useable or not. I mainly need frequency range 0 - 500 kHz for audio equipment.
Yes, it works and can use but...
it is far away what true audio work need. For this purpose - not for serious use.
First thing where is drops out is frequency resolution what is really rough due to small amount of sample points used. Other thing is speed. It is slow. Third is dynamic range. This FFT can use to some very limited purposes only or just example in basic schools, kids can take lesson number one about what is FFT with it and play rest of lesson time in classroom before this lesson one hour ends. FFT is these scopes weakest point.
But need note that of course from scope can get out raw sampledata and give it to example Matlab or what ever.
