Author Topic: Siglent SSA3000X and SSA3000X-Plus Spectrum Analyzers  (Read 626266 times)
DL4JY and 2 Guests are viewing this topic.
Offline rf-loopTopic starter
« on: October 14, 2015, 02:02:53 pm »
ETA (2021-09-01):
It is old mistake when these both models, X and Xplus are mixed here in same thread. If later Siglent produce different different models where HW etc is very different, even if model number is nearly same etc. It is best to keep both tightly in totally separate threads for avoid confusion and mess what can also see here in this thread many pelaces.
Naturally one reason for this mess is Siglent not so good product model numbering what quite easy produce confusion and mess... but here Siglent is not alone - unfortunately.
My proposal is that who ever write and comment in this thread, please inform every time in every message which one  you talk.
SSA3000X and SSA3000Xplus  are very different products!!! Even when they have lot of same functions but they have different HW and they are different in FW and different in many details, including that SDS3000XPlus HW is SVA1000X brother but SSA3000X is not.
So, please,  when you talk, make it clear if you talk about X or XPlus model.
old continue
Preliminary, coming in the near future. Siglent new Spectrum analyzer serie is SSA3000X
There is 9kHz - 2.1GHz and 9kHz - 3.2GHz models with and without tracking generator.
Min RBW 10Hz
DANL -161 dBm/Hz
Full freq range tracking gen. (2.1 or 3.2GHz) in SSA3000X-TG models
10.1"  1024x600 TFT
Some optional features and accessories.
My rough estimate about prices is ~6k$  -  <12k$   depending model without optionals.  So it is not targeted  for low end hobby markets "spectrum analyzer".  Are there also coming some cheap model for bottom entry level.... I have not seen any signs.  Price estimate was derived from some chinese sides before product was really launched.
EDIT/ADD: As we all know today, prices are totally in different class what was preliminary quessing.
Dave J.  have done nice tear down video + some compare.
https://youtu.be/-8fr_otW0q4     Teardown   (very good! )
https://youtu.be/gkLciTsjGZg      Siglent SSA3021X vs Rigol DSA815
Today we have get also TheSignalPath  well done Teardown-Review
https://www.eevblog.com/forum/testgear/siglent-ssa3032x-9khz-3-2ghz-spectrum-analyzer-review-teardown-experiments/
https://youtu.be/Fn7uaEVeOPk
« Last Edit: September 01, 2021, 05:06:27 am by rf-loop »
I drive a LEC (low el. consumption) BEV car. Smoke exhaust pipes - go to museum. In Finland quite all electric power is made using nuclear, wind, solar and water.
Wises must compel the mad barbarians to stop their crimes against humanity. Where have the wises gone?
The following users thanked this post: Martyy2k
Offline Wuerstchenhund
  • Able to drop by occasionally only
Re: Siglent SSA3000X spectrum analyzers
« Reply #1 on: October 14, 2015, 05:28:07 pm »
The UI looks certainly nice, as does the external design. The specs aren't really exciting, though:
ftp://www.siglent.com/www/Uploadfile/File/20150930/SSA3000X_datasheet.pdf
RBW: 10Hz to 1MHz
Frequency resolution: 1 Hz
Internal Reference:
Reference frequency accuracy: <0.2 ppm
Temperature stability: <1 ppm, 0 ? 5
Frequency aging rate: <0.5 ppm / first year, 3.0 ppm / 20 years
Phase Noise:
<-95 DBc / Hz @ 10 kHz offset, <-98 dBc / Hz (typ)
<-96 DBc / Hz @ 100 kHz offset, <- 97 dBc / Hz (typ)
<-115 DBc / Hz @ 1 MHz offset, <-117 dBc / Hz (typ)
Distortion and spurious response:
Second Harmonic Distortion (fc ? 50 MHz, the mixer level -30 dBm, input attenuation 0 dB, the preamplifier off, 20 ? to 30 ?): -65 DBc
Third order intercept point (fc ? 50 MHz, two-tone input level -20 dBm, frequency spacing 100 kHz, the input attenuation 0 dB, the preamplifier off, 20 ? to 30 ?): +10 DBm
1 dB gain compression (fc ? 50 MHz, the input attenuation 0 dB, the preamplifier off, 20 ? to 30 ?): > -5 DBm, nominal value
Scan Points: 751
If that's true then this is pretty expensive, considering that the 3GHz Rohde & Schwarz FSC (which has comparable specs) starts at below $6k, and that is from a big reputable brand.
Offline klaus11
« Reply #2 on: October 14, 2015, 06:13:19 pm »
HP3458A, HP3245a, Keithley 2000, Fluke 87V, Rigol DP832, TEK TDS5052B, HP33120A
Offline tautech
« Reply #3 on: October 14, 2015, 10:18:00 pm »
Preliminary, coming in the near future. Siglent new Spectrum analyzer serie is SSA3000X  ...................
Nice to see a decent image, I had heard whispers of a new SA.
Avid Rabid Hobbyist
Offline Dubbie
« Reply #4 on: October 15, 2015, 10:35:50 am »
The price does seem a bit off. Considering there are a bunch of "name brand" SA's you can get for that with equal or better specs. IMHO though, it's a really nice looking unit! (Except that ugly logo)
Sent from my iPhone using Tapatalk
Online pascal_sweden
  • Country: no
« Reply #5 on: December 03, 2015, 09:32:28 pm »
Which ugly logo? I personally think Siglent is a nice name, and the logo looks pretty neat as well!
Offline dr.diesel
« Reply #6 on: December 06, 2015, 09:01:19 pm »
This really seems like an odd exit out of the value low end T&M gear section.  IMO one would start with high quality fuller feature DMMs and "easier" equipment before jumping into the mid range SA market.
It would take some serious reviews and a 1-2 year delay before I'd buy a $12k Siglent SA.
Offline tautech
« Reply #7 on: December 23, 2015, 07:12:20 am »
Full specs and pricing are now available on Siglent websites:
http://www.siglentamerica.com/pdxx.aspx?id=1546&T=2&tid=227
Datasheet:
http://www.siglentamerica.com/USA_website_2014/Documents/DataSheet/SSA3000X_DataSheet.pdf
Edit
Add active link to datasheet.
« Last Edit: December 23, 2015, 08:04:21 am by tautech »
Avid Rabid Hobbyist
Offline awallin
« Reply #8 on: December 23, 2015, 07:33:01 am »
so those initial price estimates were only off by a factor of 4 or so...  :-DD
in that price range the direct competitors are Rigol DSA815/1030, maybe also Hameg HMS-X,  something else?
google-spreadsheet for comparisons anyone?
Offline tautech
« Reply #9 on: December 23, 2015, 08:13:55 am »
Comparison chart attached.
« Last Edit: December 23, 2015, 08:39:48 am by tautech »
Avid Rabid Hobbyist
« Reply #10 on: December 23, 2015, 11:02:35 am »
Yes. ;)
 (but still based to some facts.   (if I remember right perhaps to some older price info...)
All we know that prices in China are not cheap and if prices continue 10-20% rising per year (and some prices even more)...
But in this attached img, these are current (from Siglent web sides, china)
Offline EV
  • Aficionado
« Reply #11 on: December 23, 2015, 12:39:24 pm »
Online H.O
« Reply #12 on: December 23, 2015, 12:58:38 pm »
What?
According to this exchange rate site there's 7.07CNY to one Euro. At CNY56800 for the 3032X that would put it at around €8000, yet it's "only" €3000 in Europe. Am I using the wrong currency?
European site doesn't list the -TG option but if the 3032X is Y56600 or €3000 could we expect the -TG be around €3000/Y56800*Y66800=€3500?
Offline EV
  • Aficionado
Online H.O
« Reply #14 on: December 23, 2015, 02:21:31 pm »
Thanks, €169 makes it a no-brainer of course AND makes the chinese prices even more confusing.....Y10000 difference translates into €169....
Not that I could really justify the cost but it does put "a bit" of pressure on Rigol with their DSA-832TG which is twice the price when you include the pre-amp so for those that CAN justify it looks like a pretty good deal.
I hope they put one in the hands of Shahriar for review and teardown.
Offline awallin
« Reply #15 on: December 23, 2015, 08:00:23 pm »
Not that I am buying an SA anytime soon, but I entered some info into a spreadsheet anyway
https://docs.google.com/spreadsheets/d/1yijOHnEqQ5ffkcK3lZFgzSga9HShgZcXY4gEWarSnQI/edit?usp=sharing
(PM me if you want to edit it!)
USB, Ethernet, GPIB, etc. connectivity would be good info to add.
Hameg HMS-X doesn't look great on specs, unless you need the small size, fanless design etc.
In general DANL numbers are all over the place, a bit like fuel consumption on cars - would be better to only trust measurements done by an independent third party not the manufacturer datasheet.
Offline tautech
« Reply #16 on: December 23, 2015, 08:25:22 pm »
Nice. thanks for that, it will useful for all.  :-+
BTW
Many confuse Siglent EU (distributor)  with http://www.siglenteu.com/ the latter being the real Siglent branch in Hamburg. All official Siglent websites differ only in contact details and pricing.
However ATM both sites show the same pricing.
« Last Edit: December 23, 2015, 08:29:19 pm by tautech »
Avid Rabid Hobbyist
Offline nowlan
« Reply #17 on: December 24, 2015, 04:49:26 am »
Looking forward the reviews.
Online markone
« Reply #18 on: January 11, 2016, 01:55:20 pm »
Tg option is here:
http://www.siglent.eu/catalog/product/view/id/1111/s/siglent-tg-ssa3000x-tracking-generator-license/category/98/
That option sounds like a mere softtware licence key, does it mean that the instrument come anyway with TG HW installed and it's only matter to activate it, even after the purchase ?
On the paper this SA sounds like a winner against Rigol DSA815-TG, among other things 2.1Ghz covering range against 1.5Ghz means the you can use it for L-Band GPS & Inmarsat LNA & Antenna stuff.
The only concer is the build quality and FW support, for the first ascpect i fear it will be far inferior to Rigol.
Am i wrong ?
Anyway, someone found any test, review, "interior photo" or usage video other than Siglent "trailer".
Offline tautech
« Reply #19 on: January 11, 2016, 08:01:18 pm »
That option sounds like a mere software licence key, does it mean that the instrument come anyway with TG HW installed and it's only matter to activate it, even after the purchase ?
Yes, this appears to be the case......so stated on the Siglent websites:
http://www.siglentamerica.com/prodcut-fjxx.aspx?fjid=1562&id=1546&tid=227&T=2
On my pricelist, TG has separate pricing and if required would be added to the base model pricing.
It's likely the units SN# and ID# would be sent to Siglent for the TG enable codes if purchased without TG, in much the same way as available options are enabled after purchase in the Siglent range of DSO's.
These units have been released for not yet a month and there's been internal discussion of upcoming external reviews, all one can say is it is a job for an experienced reviewer and also not a job that takes 10 minutes to do properly.
Watch this space.  ;)
Avid Rabid Hobbyist
Online markone
« Reply #20 on: January 11, 2016, 10:58:55 pm »
Sure i will do.
For my needing at the moment would be enough a simple video showing basic task like a filter curve tracing,  some GUI iteration, maybe a shot inside, just to get a short glimpse about build quality and decide if it's the case to wait for serious reviews and not to go with Rigol right now.
Any hidden owner of this SA is advised ;-)
What attracts me over DSA815 is the superior frequency coverage, 2.1 Ghz means that it comes in handy for L-Band GPS and Inmarsat LNAs & Antennas.
Anyway, if really this instrument is on the market since one month, the complete absence of any sort of photo / video document on the WWW seems quite strange.
Offline tautech
« Reply #21 on: March 02, 2016, 08:15:23 am »
FW update released:
http://www.siglentamerica.com/gjjrj-xq.aspx?id=3615&tid=15
Changelog included.  :clap:
Edit
EasySpectrum software package too:
http://www.siglentamerica.com/gjjrj-xq.aspx?id=3616&tid=14
« Last Edit: March 02, 2016, 08:19:24 am by tautech »
Avid Rabid Hobbyist
Online markone
« Reply #22 on: March 02, 2016, 08:48:54 am »
Any review out there ?
Those SA, together new 2000X DSO lineup are like ghosts ...
Offline Pinkus
« Reply #23 on: March 02, 2016, 09:08:52 am »
My take on that: all ham amateurs and developers working on a small buget did purchase a DSA815 in the past (given a need of a SA), so this market is saturated. Now it will take much longer to bring a reasonable amount of SA devices into the market.
If I would be the marketing manager at Siglent, I would leak a hack to activate all features .... THEN the sales will boost and the coverage of the device will be everywhere. Cheapest way to gain market share and positive brand awareness.
The task for gaining negative brand awareness has already been fulfilled (google "Siglent wrongful trademark claim") by Siglent :palm:
Online markone
« Reply #24 on: March 02, 2016, 09:35:11 am »
An instrument  sample sent to Dave for a review / tear-down would come in handy to promote those new lines.
Recently the Siglent SSA3032X appeared as "available ready to ship" from Batronix (Germany), so they actually exist ....
