Orange,
Sounds like your upgrade path is a little bit different than mine. My path was
-V100.01.02.07.07 (factory version)
-V1.2.8.1
-V1.2.9.1 (lost calibration date here, was there just before the upgrade and gone right after the upgrade)
-V1.2.9.2.a
A fellow ham, Doug, and I have identical units purchased within days of each other and both having the same upgrade path (he is still at 1.2.9.1). Both unit have the calibration date. Both of us have several signal sources and consistent results (about 3.5db low). Agreed, this does not rule out the signal source.
We also both have a low cost power meter (
https://www.immersionrc.com/fpv-products/rfpowermeter/) that lends credibility that the sources are good (yes, qualitative and not quantitative).
Plan going forward:
- I contacted Siglent yesterday and reviewed the data with them.
- Tonight Doug and I will compare our Siglents against a calibrated spectrum analyzer we just got access to and document the results. I will update the forum with the results along with providing feedback to Scott at Siglent
-Scott will also research the loss of the calibration date and I'm hoping someone on the forum had similar calibration date results (my be upgrade path dependent).
- Based on your suggestion, I will snag a copy of the calibration file, hopefully later today.
73, Ron WB2WGH
