I received a SSA3021X w/ "free tracking generator option" last Monday. I have spent about 6 hours playing with it. I have a very strong technical background, but no experience using an SA despite having had 2, one dead and the other flaky. I bought this to avoid having to fix an SA in order to use it.
The Siglent hung today and required a reboot. It would not respond to ANY button presses except power. Not sure what the operation sequence was that triggered the problem. I was quite unnerved.
If I set it up to span 88-107 MHz, set the center frequency to a station, set zero span and FM demod it works. If I simply set center frequency, zero span and FM demod it sometimes appears from the screen to be demodulating properly, but the audio output is just noise. So far, the only way I've found to get it to work is set full span, reduce the span, then set the center frequency, zero span and FM demo in that order. Changing the center frequency to tune to a different station may or may not work. So damn poor operation relative to an RSP2 for 1/10th the price.
There is a maddening tendency for it to reset things not shown as a side effect of setting some other parameter. As a new user I don't yet know if it's a bug or user error.
The unit has trial keys for all the options, but they time out based on operating time of the unit, not the option. So I lost 6 of the 48 hours of use provided because I left it running on my bench while I did some household chores with it sitting on the default start up settings with a 50 ohm terminator on the input.
The root login has not changed, but the firmware is 1.2.8.2, so I presume that the "hack' does not work. I don't care to try. My interest is self maintenance. An email to Siglent seeking a service manual produced the response that it was not finished but would be made available when it was finished. For a product that's been on the market for a couple of years that's a very uncomfortable answer.
A number of searches failed to locate the source code for the GPLed parts of the firmware.
The USB cable supplied lacked an RF choke. I'm using a cable I had instead. In view of the intended uses of the product I found the supplied cable pretty dubious.
The user manual is not very helpful. I've largely been mashing buttons and seeing what happens. I understand SA design fairly well, so I think I have reasonable expectations. However, I have found that the sweep speed is a lot slower than I'd expected. But without experience with an HP I have no idea whether my expectations are reasonable or not.
