What are detector settings used in these images. Is it quite important information?
Everything default (detector set to average)
This image 1 (atten 0, ampl 0) result is still so strange that I want ask agen more detailed.
Question 1 (most important)
Trace and Detector settings. I do not know what are S&H defaults. Im interest what are in use, exactly. (and because this result is so "amazing")
In S&H (BB60C) user interface there is perhaps these settings:
Left top corner
Traces
- Type = Clear&Write (If not this, then what?)
Right bottom corner
Acquisition
- Video Units = Power (If not this, then what?)
- Detector = Average (you tell it was this)
Question 2
If there is (of course detector - Positive Peak)
0 attenuation and 0 amplifier. What is maximum reference level.
Question 3 (but this need also enough accurate instruments)
Then next what is maximum signal level what do not clip or is not highly compressed when atten 0 and ampl 0.
(you can test it roughly IF you have good or better RF signal generator what have trusted levels what you can adjust and follow what level S&H cursor measure when you adjust level example from -50dB to up as far as S&H can follow this level without starting clip/compress.)
Best to use quite low frequency, example something between example 10 - <100MHz.
This is because I still wonder why base noise power with this setting
looks like nearly 20dB higher than expected and around 20db here is really lot of.
Reason for this question is here in these two images.
SSA3000X. Same settings, 0dB atten, Amplifier OFF, RBW300kHz, Detector WideoAve mode LogPower, ref_-30dBm
First image in « Reply #22 on: August 05, 2016, 11:45:31 PM »
