Author Topic: New firmware Keysight InfiniiVision 2000A&3000A  (Read 528 times)
Offline LA7SJA
  • Country: no
  • Acting user manual reader & forum search engine
« on: April 16, 2017, 08:51:47 pm »
The new firmware is from 2017-03-29 and is version 2.42.
http://www.keysight.com/main/software.jspx?ckey=2014479&lc=eng&cc=US&nid=-11143.0.00&id=2014479
Enhancements for both 2000A and 3000A
- Both the DVM and training signal features are now included as standard.
- Probe attenuation can now be set down to 0.001
Enhancements for the 3000A
- Remote User Interface support was added for the N2820A probe.
Bug Fixes for both 2000A and 3000A
- An issue with certain timebase changes affecting waveforms displayed in high resolution or averaging mode has been corrected.
- An issue with Single acquisitions in averaging mode has been corrected.
- Certain conditions are now better propagated through the AER and TER registers.
- The timebase delay control limit is now better calculated.
- Improvements were made to the FFT algorithm for certain conditions.
- An issue with the channel invert function and setup files was corrected.
- An issue with the Delay measurement sometimes not measuring from the edge closest to the trigger reference point has been corrected.
- An issue with the calculation of the length header for ASCII formatted binary blocks has been corrected.
- An issue with clearing the trigger event register (TER) with *CLS has been corrected.
- An issue with saving an FFT .csv file has been corrected.
- The VTIMe measurement now works properly on digital channels.
Bug Fixes for the 3000A
- Certain N7020A probe calibration failures are now more accurately detected.
Bug Fixes for the 2000A
- The Trig 50% feature now works properly on 2 channel scopes.
Release Notes:
http://www.keysight.com/upload/cmc_upload/All/Keysight_2000A_3000A_X_Series_Oscilloscope_Release_Notes_02_42.pdf
Johan-Fredrik
"If at first you don't succeed, skydiving is probably not for you"
Online gslick
Re: New firmware Keysight InfiniiVision 2000A&3000A
« Reply #1 on: April 17, 2017, 12:17:33 am »
See also this thread from April 06, 2017:
Free DVM & Training Signals for Keysight 2000X and 3000A oscilloscopes
http://www.eevblog.com/forum/testgear/free-dvm-training-signals-for-keysight-2000x-and-3000a-oscilloscopes/
The following users thanked this post: LA7SJA
