Author Topic: Software for spectrum analyzer Hameg HM5014-2  (Read 6646 times)
Offline Biff45Topic starter
« on: September 02, 2017, 06:31:52 am »
I´m looking for the software original shipped with an Hameg HM5014-2. I think its called AS100E base version.
Any hints for open source alternatives are welcome too.
Best reguards,
Biff
Offline Rob_R
Re: Software for spectrum analyzer Hameg HM5014-2
« Reply #1 on: September 09, 2017, 07:25:08 pm »
The original CD version I have is v2.1.
But I also have the AS100e v3.05 update ,which I have uploaded to.......
https://www.        sendspace.          com/file/4perp3
HTH Rob.
Offline acrogen
« Reply #2 on: November 11, 2017, 02:01:31 pm »
Hello ROB_R,
Funnily enough I am just getting my HM5014-2 software loaded.
Rohde-Schwartz very helpfully sent me exactly this version of software a couple of days ago.
On installing it comes up with a message saying it has installed some files and then needs to be restarted.
I restart it and it says exactly the same thing.
I have tried it on several computers, different makes, versions of Windows etc etc but it is always the same result.
I saw your copy and tried that but it does exactly the same thing.
Any ideas?
When the zip file is unzipped it puts this into a temp or download in the computer but when the .exe file is run from there it puts it into its pre-arranged folder.
My guess is that the link to where it stores the special files it creates when the proper program is run for the first time initially is not the same link as where it looks for them to see if they are installed.
Did you have any problems with this??
Thanks
Ray
Offline acrogen
« Reply #3 on: November 17, 2017, 08:58:20 am »
Hello,
Since my post, I have contacted  Rohde & Schwarz  again and they said the software has to be run on computers running old Windows software only.
10/10 to R and S for supporting on their help-desk an old legacy product.
We thought we were running on an XP computer but on closer inspection it was updated somehow?
Anyway we dusted off an even older computer that was definitely XP and the software now works fine.
Interesting point was that we intended to use a USB to serial converter.
This would not work on XP machine as it was too old to be supported by USB to serial converter!!
However the old computer still had RS 232 port so all was well.
Ray
Offline DF1DA
AS100E SW for spectrum analyzer Hameg HM5014-2 on Windows 7
« Reply #4 on: December 09, 2017, 07:42:57 am »
Hello,
I bought a refurbished HM5014-2 last weekend and came to the same known problem with installing the AS100E SW on my Windows7 laptop.
The SW always pretended to extract files into the installation directory and asked to restart it.
Looking into the directory there were no additional files copied.
And at restart the SW again the same effect.  |O
After a lot of fruitless trial and run, I decided to reinstall the Software, but instead of the default proposed path I chosed "C:\HAMEG".
And - bingo- now the additional files were extracted into the same folder and the SW afterwards started as expected.  :-+
This might help others using the SW on Windows 7.
I did not try on my Windows 10 workstation yet.
Regards, Gerhard, DF1DA
« Last Edit: December 09, 2017, 07:48:42 am by DF1DA »
Offline nctnico
« Reply #5 on: December 09, 2017, 10:48:08 am »
That sounds like the software doesn't run on Windows versions where 'Program files' directory cannot be written by the user.
Offline The Chump
« Reply #6 on: December 09, 2017, 08:08:24 pm »
I got this to run on Windows 10 64bit. nctnico has the nub of the problem right.
You need to go to Program Files (x86)\AS100E\ (or wherever you installed it) and right click on "dllarc.exe" and chose "Run as Andministrator".
That will extrtact the dlls. After that it works just fine, even with USB serial ports as long as they are on COM1,2,3,4
Your saved plots are saved in some kind of Access database format.
I use Axbase (https://sourceforge.net/projects/axbase/) to get the data from the .mdb files
Cheers
Alex
« Reply #7 on: March 16, 2018, 02:22:04 pm »
Or you change the install path to a folder where non admin users can write. This works for me.
Offline mr.gigi
« Reply #8 on: November 24, 2018, 12:03:42 pm »
Hello everyone,
Sorry for reviving an old topic, didn't want to create a new topic for something this minor.
Can anyone help me with a copy of AS100e software? if I can i will return the favor ;D
Thank in advance.
Offline inkantis
« Reply #9 on: February 17, 2019, 10:58:46 pm »
Hello everyone!
I've also recently gotten this Spectrum Analyzer. I wanted to try the software. Would someone be so kind as to make the software available?
Offline szymon019
  • Passionate Electronics Developer
    • Electronics R&D Laboratory & Prototyping
« Reply #10 on: January 11, 2020, 12:47:36 pm »
Hello Colleagues!
I recently had chance to got HM5014-2 spectrum analyser too. I tried software on windows XP and it works but on WIN7 x64bit even installed on C:\hameg with added all possible read/ write rights started with XP compatibility and  with administrator rights. Program  starts after some time but after that it hangs. Main program frame is displayed but internal frame with spectrum isn't displayed. COM port PCIe card is configured as COM1 and under windows XP AE100S  3.05 it works properly. I unpacked mentioned before dlls.
Instrument firmware 1,23, key 2,0.
This software in combination with spectrum analyzer seems to be still ok for development of some side projects which will works under 200MHz (5th harmonic rules = 1GHz)
I would like to mention that tested this software under LINUX WINE which emulates win7 - the same effect like on standard windows 7.
Do you have any idea how to force it to be operational on WIN7 or LINUX WINe??
910116-0
910120-1
Best Regards
Szymon K.
« Last Edit: January 18, 2020, 11:32:36 am by szymon019 »
Offline szymon019
« Reply #11 on: January 23, 2020, 12:00:38 am »
Seems to be solution.
1)You need to active ACTIVEX instalation in windows services to start with OS.
2) Probably install Visual Basic 6 runtime (I installed)
3) Register this manually C:\HAMEG\Regsvr32 GRID32.OCX
since this moment ;) you can enjoy your new / old tool
Offline ODO Tronic
  • Country: no
« Reply #12 on: December 12, 2020, 04:45:07 am »
Hello,
Can anyone help me with a copy of the AS100e software ?
I happy to return a favor to anyone that can share the software with me.
Br.
Peter
Offline fberna
« Reply #13 on: April 09, 2021, 03:50:05 pm »
I wrote to R&S a mail asking for the software. Less than 2 hours later I got a link to download it.
If anyone needs this program just send me a message to fberna62@gmail.com
Installed and followed the instructions from The Chump.
It works flawlessly on win 10
« Last Edit: April 09, 2021, 05:21:36 pm by fberna »
Offline s.marco
« Reply #14 on: May 05, 2021, 02:55:27 pm »
Hi, I'm new with this software and in the EMC mode I don't understand what are the Hor/L Ver/N buttons for?
I attached a photo.
Can someone help me?
