Quote from: Neilm on November 06, 2018, 08:16:26 pmI have seen glass fuses used in meters that claimed CAT III 250 V protection. They exploded when there was a transient.a) There's no such category as "CAT III 250V"b) See the million threads about false CAT ratings on multimeters.c) The meter is allowed to die, all that's required in the CAT system is to protect the user.CAT ratings chart:Quote from: Neilm on November 08, 2018, 08:18:54 pmIEC61010 notes a 1 kV CAT IV situation will have a potetial short circuit current of >>25 kA.I'm not sure where that number comes from.1kV with 2 Ohms impedance is 500A. A 12kV transient with 2 Ohms impedance is 6kA for the duration.
if you put the probe across voltage when meter is in current
Quote from: HKJ on November 09, 2018, 06:07:12 pmif you put the probe across voltage when meter is in current The trick is NOT to do that.
Quote from: Fungus on November 09, 2018, 06:12:34 pmQuote from: HKJ on November 09, 2018, 06:07:12 pmif you put the probe across voltage when meter is in current The trick is NOT to do that.Of course it is, but I prefer a meter where you do not get an instant suntan (or worse) if you make the mistake. I.e. the fuses have a 10kA+ breaking rating.
Quote from: Neilm on November 06, 2018, 08:16:26 pmI have seen glass fuses used in meters that claimed CAT III 250 V protection. They exploded when there was a transient.I don't think an exploding glass fuse in an enclosed chassis contradicts a CAT rating.
