I just noticed, that there is something strange going on at 3.12 Ghz on my SSA3032x when switching from a lower BW to 3 MHz BW.
Find attached a screenshot comparing the same 3.12 GHz source at 0.1, 1 an 3 MHz BW.
Also attached is the initial sweep where i discovered the "bug"?!
[EDIT]When you let the source sweep across that frequency range, you see a lot of different variants of distortions - but only when BW is set to 3 MHz.
[EDIT2]Similar Problem at around 1.03 and 2.07 GHz!
