Author Topic: Suggestion choosing an hobby signal generator (jds6600, fy6800, UTG1005A)  (Read 3495 times)
Offline kirysTopic starter
    • Kirys.it
Hi all
I know that there are many topic with this question but I need an opinion of some products I didn't see a review yet.
I need 2 channels but I don't need a large bandwidth and the price should be less that 200€.
At the begin I was considering the jds6000 (about 90€ 15mhz model) that looked "safe" (it's easy to add a linear power adapter) and good enough for me.
but I saw also these two:
  • the new fy6800 that has some nice features (modulation) and it's grounded (110€ 30mhz model).
  • and the uni-t UTG1005A that it's 165€ on amazon (but it's only 5mhz).
The fy6800 is new so there are still not many review around while the uni-t seems unknown even though its not a recent model (but looks of higher quality that the other two devices).
What do you think?
Thank you
K.
Offline Candid
If the JDS6600 is good enough for your needs then I would get it. It is a good product for an affordable and very fair price.
The FY6800 is more ore less like the FY6600, no big enhancement and about the FY6600 you can find a long and informative thread at the EEVBlog forum. The JDS uses an external psu so can very easy get rid of the ghost voltage problem and it is still floating. I don't know the UNI-T UTG1005A.
Offline GregDunn
I have a FY6800 (KKMoon branded).  It has an internal power supply w/IEC connector and fuse and the "phantom" voltage issue appears to have been fixed; those two details make it an easy choice over the FY6600.  There are a few quirks in the user interface but it's an extremely powerful AWG and does far more than I'll probably ever need.  I primarily work in audio, and the 6800 has extremely low distortion as well as sweep capabilities with an output which can be used to drive a scope for swept frequency measurements.  I also like the much better display vs. the older 2-line LCD models.
Offline Mechatrommer
  • Country: my
  • reassessing directives...
Re: Suggestion choosing an hobby signal generator (jds6600, fy6800, UTG1005A)
« Reply #3 on: December 25, 2019, 11:34:48 am »
i know this is few months back, but if you have to include UTG line, there is a new model few weeks back $130 60MHz... UTG962 or UTG962E...
UNI-T UTG932/UTG962 200MSa/s Function Arbitrary Waveform Generator
« Last Edit: December 25, 2019, 11:37:11 am by Mechatrommer »
