*Cell phone network* analysis, or signal analysis, as its not a VNA, just 'network analysis' alone could be confusing. Also, the 10Mhz is the realtime bandwidth (I.e. it can digitize 10Mhz of spectrum and run a FFT/DFT on it in real time so you can examine modulation etc), as you can see from the options, it was meant to be used on CDMA, EDGE/ GSM networks. I havent used a VSA series analyzer before, only the newer MXA series which does support full span as a swept spectrum analyzer. No FFT real time unless your span is under the RTBW. I cant find anything in a brief peruse of the manual to indicate one way or the other, so find out for sure if youre interested in it as a swept SA. However I'd save my $$$ for a spectrum analyzer with a tracking generator, which is ridiculously useful compared to one without IMO.
Sorry my terminology was not up to par.
Anyways I found an interesting discussion about it:
http://www.home.agilent.com/owc_discussions/thread.jspa?messageID=62538
It seems it has a very low noise-floor.
No problem, I'm sure terminolgy varies from place to place anyway. I'm sure there are cell phone network techs who havent touched a VNA and would call the VSA a network analyzer.
Interesting that it doesnt support a sweep! I wonder if its not real-time then, I'd suspect not.
A vector signal analyzer/realtime VSA is basically a tunable RF down converter ( i.e. converts 100-110 MHz to 0-10 MHz) to stuck in front of high-resolution/low noise DSO (I.e. it digitizes the waveform) where it then processes the signal to give frequency domain information instead of time domain. A realtime VSA can continuously acquire the data, and process it before the next chunk of data is ready. A 'plain' vector signal analyzer will have some deadtime.
shows what signal analyzers can do vs swept spec-ans.
