Author Topic: Taking humidity readings: newbie question  (Read 1185 times)
Offline midgk0Topic starter
« on: August 09, 2018, 09:20:54 am »
Hi there,
I hope this question hasn't already been asked: I did search and couldn't find anything. I've just started a job that involves measuring the temperature and humidity of various spaces. I've been given a Precision Gold N21FR multimeter to take spot readings, though I am thinking of proposing we buy some recording thermohygrometers for longer-term readings. Anyway, when I use the spot meter in some of the spaces, the humidity reading just keeps dropping. Sometimes this will be quite quick and it will level out, but other times I can wait 15 minutes and it still keeps dropping by 0.1% every 30 seconds or so. I was wondering whether I should try to wait for it to stop dropping, but perhaps that won't happen? Or should I choose an amount of time with a stopwatch and take a reading after the time has elapsed, regardless of whether it is still dropping or not? Sorry if this is a daft question, I just want to make sure that the data I'm logging is actually useful!
Many thanks,
Katherine
Online IanB
Re: Taking humidity readings: newbie question
« Reply #1 on: August 09, 2018, 09:28:20 am »
Bear in mind that that meter is not a precision instrument, so the readings will not be highly accurate.
I found what looks like the manual online and it seems that for relative humidity readings the accuracy is about plus/minus 5% and you should wait up to 15 minutes for the reading to settle before taking a measurement.
https://maplindownloads.s3-eu-west-1.amazonaws.com/N21FR-8667.pdf
« Reply #2 on: August 09, 2018, 09:54:50 am »
That's what I thought: it would be better to use the spot meter to supplement the readings of a recording thermo-hygrometer. I will try leaving it for 15 minutes, to see if that makes a difference. Thanks for your help! :)
Offline mzzj
« Reply #3 on: August 09, 2018, 10:10:02 am »
Hi there,
Many thanks,
Katherine
Cheapest, crappiest humidity sensors behave pretty much like you describe, settling time can be several days! to last 1-2% vs 15 minutes with a "proper"* good humidity sensor.
Low humidity is typically the problematic area for cheapest sensors/meters, your meter has NO response time specification whatsoever below 45% RH  :-DD
*) humidity meters from manufacturers like Vaisala, Rotronic and E+E
« Reply #4 on: August 09, 2018, 10:49:27 am »
Thank you, good to get some advice about a better brand! I thought as much due to the vagueness of the instruction manual and the fact that it measures *everything*, never a good sign...
