Hi.
I bought a TC1 transistor checker from banggood. It seems fine as I can measure bjts, mosfets, capacitors fine. However, i came across a thyristor or SCR , TYN612M, when I measure it the checker shows a BJT transistor with hfe, Ic, and Vbe of 0.
The SCR is new and working fine. Also tested with DMM to make sure.
Does anyone have any idea why is this?
I dont understand the method the tester uses to identify the parts so, im not sure if I can troubleshoot it.
