Okay, had a look at the service manual and found the answer: R838,839 are metal oxide resistors, hence have a rather low inductance. But then, there are two inductors L801,802 in series ("peaking coils")...
If your adventurous and like experimenting, you could get two 15k Vitrohm series 214-8 resistors. These are 9W and will have some 250µH inductance (measured at 100kHz). When replacing R838,839, the total inductance will rise, but that probably won't hurt. But these are rather big: 9 x 9 x 38mm - and Mouser doesn't seem to have them.
The 5W metal oxide resistors Xicon 286-15K-RC (Mouser) would be the safer bet.
And then, you could not change anything and just ignore these two little toasters in your scope ...
