It would be good to know which meters you like the most. Not necessarily based on their specs or technical merit, which meters you like and enjoy using.
ie. When you need a meter, which one do you instinctively grab?
Which meters are languishing in a drawer and will probably never see the light of day ?
You could maybe have three categories with a couple of meters in each:
Hobby meter, not safe for mains work but fine for low voltage bench work.
Safe for mains work, certified CAT rating.
Overall favorite meters.
Mostly I like and use high end meters:
Fluke 179: A fairly simple meter (Compared to the ones below), it has never been my primary meter, but often get used to check stuff.
Fluke 189: My favorite Fluke meter.
Fluke 289: It is good for something, but it is slow to turn on and has low contrast on the display
Gossen Metrahit Energy: I bought it because it could measure power, but I also love that it auto ranges from uA to 10A and you never blow a x00mA fuse in it. It has often been my favorite meter for measuring current, but now I have a power supply with a very good current readout and some bench AC power meters, this means I do not use it as often anymore.
Keysight U1252B: I have been using that for some time, it has a silly layout with the buttons and the rechargeable battery got swapped with a primary before it was empty first time.
Keysight U1282A: I have been using this a bit, but I am not very impressed with its speed.
Hioki DT4282: After my review I decided to try this out as my main meter, I like the speed of it.
Many of the meters has also been used for logging with a computer, this means they have been running for
many hours, but mostly I have changed to bench meters for this.
In the multimeter table on my website is a rough safety evaluation of each meter (You can sort on any column)
