Author Topic: Technical multimeter review and tear-down, more than 110  (Read 31290 times)
Offline HKJTopic starter
    • Tests
« on: April 25, 2018, 09:26:17 am »
Each review contains:
  • Lots of photos.
  • Schema with most ranges and feature that is easy comparable between my reviews.
  • General precision check of some ranges
  • Check of input impedance in V, LowZ and mV.
  • Check of capture speed for min/max/peak.
  • Check of frequency counter sensitivity, bandwidth and input impedance (Impedance is usual not 10Mohm)
  • Check of duty cycle maximum frequency and precision
  • Check of burden voltage at different currents.
  • Check of voltage and current in ohm, continuity, diode .
  • Check of speed for ohm, continuity, capacity.
  • Meter current consumption
  • Behaviour when battery is low/empty.
  • Estimate battery life based on actual current consumption and my battery tests.
  • Tear down with some explanation
Chronological, newest first
Aneng AN82 - East Tester ET3240 - Mustool MT110 - UNI-T UT258A - UNI-T UT123 - Aneng M20 - Mestek DM90S - Mestek CM81 - Mustool X3 - Mustool MDS8207
Keysight U1282A - Bside ADMS6 - BTMeter BT-570C-APP - DMM BSide ADMS7 - Aneng V8 - Aneng V7 - Brymen BM829s - Mastech MS8211 (Aimo) - Owon B41T+ - UNI-T UT125C
Kyoritsu KEW1030 - Vici VC835 - Kyoritsu KEW1062 - Aneng H01 - WH5000A - UNI-T UT195E - Mestek DM91A - Mastech MS2108A - Hioki 3246-60 Card HiTester - BTMeter BT-39C
Eone ET201 - Mastech MS8340B - Borbede BD-168B - UNI-T UT191T - HoldPeak HP-4201 - Mustool MT108T - BSide ADM20 - Victor 98A+ - PeakMeter PM18C - Owon B35T
Aneng AN8203 - Mastech MS8040 - Mustool MT109 - Aneng AN882B+ - WinApex ET8102 - Siglent SDM3045X - Sanwa PS8a - HoldPeak HP-770D - Aneng V01A - Keithley DMM6500
Mustool MT8206 - Bside ADM92 - Hioki 3244-60 Card HiTester - Aneng AN302 - UNI-T UT61E - NEWACALOX DT33D - Keysight 34461A 6½ digit - BSide ADM04 - UNI-T UT139S - Hyelect MS8232
EEVBlog 121GW - Aneng Q1 - HoldPeak HP-38B - PeakMeter PM8211 - Brymen BM525s - Mastech MS8212A - UNI-T UT118B - ANENG B01 - HY-19E - HoldPeak HP-770C
DT-830D+ - Mastech MS8218 - LAOA LA814103 - VC105 - BSide ZT301 - Mustool MT66 - Fluke 289 - UNI-T UT195DS - DT9208A - Sanwa PM3
BSide ACM91 - Hioki DT4282 - UNI-T UT171A - UNI-T UT120C - Aneng AN870 - Peakmeter MS8229 - Mastech MS8216 - Brymen BM869s - Mastech MS8268 - Brymen BM27s
All-Sun EM3081 - Vici VC8145 - Handskit 117C - Uyigao UA18 - Aneng AN8002 - Amprobe AM-570 - 5 in 1 (VA19) - Aneng Mini 180 - Prova 903 - XB-866
Brymen BM235 - Innova 3320 - UNI-T UT33A+ - UNI-T UT33D+ - Aneng AN101 - Klein Tools MM600 - BSide ZT302 - Peakmeter MS8248S - SNDWAY SW-890C - DT-830B
Keysight U1233A - Aneng AN8009 - Zeast 282 - Mastech MS8229 - Southwire 16040T - XL830L - Amprobe AM-510-EUR - UNI-T UT139C - Aneng AN860B+ - Fluke 17B+
UNI-T UT210E - Aneng AN8008
My list of good meters
This list is meters with all current ranges, temperature, frequency and led test with at least 4000 count. I have also excluded the lowest safety category. Nearly of them will be very good hobby meters (Check reviews) and some of them are also good professional meters (Requirement for professional is good safety up to max. supported voltage, i.e. correct CAT marking)
East Tester ET3240 - Aneng M20 - Keysight U1282A - Aneng V8 - Aneng V7 - Brymen BM829s - Owon B41T+ - Kyoritsu KEW1062 - WH5000A - BTMeter BT-39C
Borbede BD-168B - UNI-T UT191T - Mustool MT108T - BSide ADM20 - Victor 98A+ - Mastech MS8040 - Aneng AN882B+ - WinApex ET8102 - HoldPeak HP-770D - Keithley DMM6500
Keysight 34461A 6½ digit - UNI-T UT139S - EEVBlog 121GW - Brymen BM525s - HY-19E - BSide ZT301 - Mustool MT66 - Fluke 289 - Hioki DT4282 - Aneng AN870
Brymen BM869s - Brymen BM235 - Klein Tools MM600 - Zeast 282 - UNI-T UT139C - Aneng AN860B+
By brands
All-sun: EM3081
Amprobe: AM-510-EUR - AM-570
Aneng: B01 - AN101 - AN302 - AN8002 - AN8008 - AN8009 - AN8203 - AN82 - AN860B+ - AN870 - AN882B+ - H01 - M20 - Mini 180 - Q1 - V01A - V7 - V8
BSide: ACM91 - ADM04 - ADM20 - ZT301 - ZT302 - ADM92 - ADMS6
Brymen: BM235 - BM27s - BM525s - BM829s - BM869s
Fluke: 17B+ - 289
Hioki: 3244-60 Card HiTester - 3246-60 Card HiTester - DT4282
HoldPeak: HP-38B - HP-4201 - HP-770C - HP-770D
Innova: 3320
Keithley: DMM6500
Keysight: 34461A 6½ digit - U1233A - U1282A
Klein Tools: MM600
Kyoritsu: KEW1030 - KEW1062
Mastech: MS2108A - MS8040 - MS8211 (Aimo) - MS8212A - MS8216 - MS8218 - MS8229 - MS8268 - MS8340B
Mestek: CM81 - DM90S - DM91A
Mustool: MDS8207 - MT108T - MT109 - MT110 - MT66 - MT8206 - X3
Owon: B35T - B41T+
Peakmeter: PM18C - PM8211 - MS8229 - MS8248S
Sanwa: PM3 - PS8a
Siglent: SDM3045X
Southwire: 16040T
UNI-T: UT118B - UT120C - UT123 - UT125C - UT139C - UT139S - UT171A - UT191T - UT195DS - UT195E - UT210E - UT258A - UT33A+ - UT33D+ - UT61E
Vici: VC8145 - VC835
Victor: 98A+
Other: East Tester ET3240 - BTMeter BT-570C-APP - DMM BSide ADMS7 - WH5000A - BTMeter BT-39C - Eone ET201 - Borbede BD-168B - WinApex ET8102 - NEWACALOX DT33D - Hyelect MS8232 - EEVBlog 121GW - HY-19E - DT-830D+ - LAOA LA814103 - VC105 - DT9208A - Handskit 117C - Uyigao UA18 - 5 in 1 (VA19) - Prova 903 - XB-866 - SNDWAY SW-890C - DT-830B - Zeast 282 - XL830L
By size/type
Pocket: All-Sun EM3081 - Aneng AN101 - Aneng AN302 - Aneng AN8203 - Brymen BM27s - Hioki 3244-60 Card HiTester - HoldPeak HP-4201 - LAOA LA814103 - Mastech MS8216 - Sanwa PM3 - Sanwa PS8a - UNI-T UT120C - Uyigao UA18 - XB-866
Pen: ANENG B01 - Hioki 3246-60 Card HiTester - HoldPeak HP-38B - Kyoritsu KEW1030 - Mastech MS8211 (Aimo) - Mastech MS8212A - PeakMeter PM8211 - UNI-T UT118B
Small: Aneng AN8002 - Aneng AN8008 - Aneng AN8009 - Aneng Mini 180 - Aneng V01A - BSide ADM04 - Bside ADM92 - Bside ADMS6 - DMM BSide ADMS7 - DT-830B - DT-830D+ - Hyelect MS8232 - Innova 3320 - Mustool MT66 - NEWACALOX DT33D - Southwire 16040T - UNI-T UT123 - UNI-T UT125C - UNI-T UT33A+ - UNI-T UT33D+ - XL830L
Medium: Aneng AN82 - Aneng H01 - Aneng M20 - Aneng Q1 - BSide ZT301 - BSide ZT302 - BTMeter BT-39C - Borbede BD-168B - Brymen BM235 - EEVBlog 121GW - Keysight U1233A - Mestek DM90S - Mestek DM91A - Mustool MDS8207 - Mustool MT108T - Mustool MT109 - Mustool MT110 - Mustool MT8206 - Owon B41T+ - Peakmeter MS8248S - Vici VC835 - WinApex ET8102
Large: 5 in 1 (VA19) - Amprobe AM-510-EUR - Amprobe AM-570 - Aneng AN860B+ - Aneng AN870 - Aneng AN882B+ - Aneng V7 - Aneng V8 - BSide ADM20 - DT9208A - Eone ET201 - Fluke 17B+ - HY-19E - Handskit 117C - Hioki DT4282 - HoldPeak HP-770C - HoldPeak HP-770D - Klein Tools MM600 - Kyoritsu KEW1062 - Mastech MS8229 - Mastech MS8268 - Owon B35T - PeakMeter PM18C - Peakmeter MS8229 - SNDWAY SW-890C - UNI-T UT139C - UNI-T UT139S - UNI-T UT191T - UNI-T UT195DS - UNI-T UT195E - UNI-T UT61E - VC105 - WH5000A - Zeast 282
VeryLarge: Brymen BM525s - Brymen BM829s - Brymen BM869s - Fluke 289 - Keysight U1282A - Mastech MS8218 - Mastech MS8340B - Prova 903 - UNI-T UT171A - Victor 98A+
Clamp: BSide ACM91 - BTMeter BT-570C-APP - Mastech MS2108A - Mestek CM81 - Mustool X3 - UNI-T UT210E - UNI-T UT258A
Bench: East Tester ET3240 - Keithley DMM6500 - Keysight 34461A 6½ digit - Mastech MS8040 - Siglent SDM3045X - Vici VC8145
Suggestions for improvements of the reviews are welcome (I may not follow them). Ideas for other meters to review are also welcome.
I still have most of the meters and can check/verify stuff if there are questions.
A parameterized list of the reviewed meters can be found here Multimeter selection table
Other stuff about multimeters:
Multimeter guide
Multimeter and component testing
Multimeter probes
Multimeter and voltage measurements
Multimeter and pulsed DC current (PWM)
Tolerance specifications for multimeters
Clamp meters magnetization, demagnetization and offset
Multimeters and current measurements
Multimeters and thermocouples
Multimeter design
Multimeter protection and safety
Offline nctnico
Re: Technical multimeter review and tear-down, more than 40
« Reply #1 on: April 25, 2018, 11:22:38 am »
Nice work. Perhaps you could categorise the meters by handheld and bench models as well.
The following users thanked this post: square circuit
    • Tests
« Reply #2 on: April 25, 2018, 11:39:52 am »
I have added a table showing them by the size categories I use on my website. The definition of the different types are listen on my website at the bottom of the multimeter table.
Offline Fungus
« Reply #3 on: April 25, 2018, 03:29:36 pm »
It would be good to know which meters you like the most. Not necessarily based on their specs or technical merit, which meters you like and enjoy using.
ie. When you need a meter, which one do you instinctively grab?
Which meters are languishing in a drawer and will probably never see the light of day ?
You could maybe have three categories with a couple of meters in each:
Hobby meter, not safe for mains work but fine for low voltage bench work.
Safe for mains work, certified CAT rating.
Overall favorite meters.
    • Tests
« Reply #4 on: April 25, 2018, 05:12:00 pm »
Mostly I like and use high end meters:
Fluke 179: A fairly simple meter (Compared to the ones below), it has never been my primary meter, but often get used to check stuff.
Fluke 189: My favorite Fluke meter.
Fluke 289: It is good for something, but it is slow to turn on and has low contrast on the display
Gossen Metrahit Energy: I bought it because it could measure power, but I also love that it auto ranges from uA to 10A and you never blow a x00mA fuse in it. It has often been my favorite meter for measuring current, but now I have a power supply with a very good current readout and some bench AC power meters, this means I do not use it as often anymore.
Keysight U1252B: I have been using that for some time, it has a silly layout with the buttons and the rechargeable battery got swapped with a primary before it was empty first time.
Keysight U1282A: I have been using this a bit, but I am not very impressed with its speed.
Hioki DT4282: After my review I decided to try this out as my main meter, I like the speed of it.
Many of the meters has also been used for logging with a computer, this means they have been running for many hours, but mostly I have changed to bench meters for this.
In the multimeter table on my website is a rough safety evaluation of each meter (You can sort on any column)
The following users thanked this post: 001
Offline Fungus
« Reply #5 on: April 25, 2018, 05:58:40 pm »
That Hioki has its flaws but it seems well-liked by people who actually use it.
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #6 on: April 25, 2018, 07:41:49 pm »
I have seen some of your reviews before; thank you for posting a comprehensive list.
Offline mqsaharan
  • Country: pk
« Reply #7 on: April 27, 2018, 08:29:13 am »
Hi HKJ,
Really nice work. I like your reviews. I read quite a few of them. They are concise and from a practical point of view. I like that you have not censored the drawbacks/bad points.
It has been said countless times that the user of such an equipment should learn how to use it, its shortcomings and its limitations. But unfortunately the manufacturers hide such information and not everyone has access to a full blown electronics lab to understand the behaviour of such equipment and such reviews help a lot. Please keep it up.
May I request you to post reviews for your Fluke 189 and 289. The teardown for these is not that necessary (as you may not want to take them apart) but I was hoping for their reviews along the lines of your Brymen BM869s and Hioki DT4282 reviews.
Regards,
Qasim.
    • Tests
« Reply #8 on: April 27, 2018, 09:28:40 am »
I am a bit in two minds about that, all the meters I have reviewed above are new and I can also  show what you get with the meter.
I have some high-end meters and the technical information for them could be interesting to include, but a review of a old meter is not the same as the review of a new meter.
Offline nanofrog
« Reply #9 on: April 27, 2018, 01:05:56 pm »
I understand your hesitancy to include old/used meters with new ones. But keep in mind, it seems most of us try and utilize the used market whenever possible. So reviews of older meters such as the Fluke 189 & 289 have merit IMHO.
Determining which ones to include would be the hard part, but suggestions from various geo-locations should help narrow that down considerably (and someone may be able to donate a specimen for review).
For clarity, you could always separate them in NEW & OLD lists. Any personal usage comparative comments would be appropriate in the conclusion section.
Just a thought.  :)
The following users thanked this post: mqsaharan
Offline mqsaharan
  • Country: pk
« Reply #10 on: April 28, 2018, 05:31:22 am »
nanofrog has already put my reason in better words. I am just repeating what he said.
I requested for their review Because they are used and since You are the original owner you can give better comments on their true (and not assumed) quality.
You can also compare their deviation (if there is any) from the "Production Verification Test Data" that you received with them against their current display readings using your higher precision and higher resolution bench meters thus telling us how they held up with your usage, etc. (just another thought).
Regards,
Qasim.
    • Tests
« Reply #11 on: May 09, 2018, 02:59:09 pm »
I have tested on the 289 and started on a review.
I have add a couple more reviews to the list.
The following users thanked this post: kj7e
Offline Hydrawerk
« Reply #12 on: May 09, 2018, 09:58:14 pm »
Thank you.
    • Tests
« Reply #13 on: May 17, 2018, 03:34:18 pm »
The Fluke 289 review is now published.
The following users thanked this post: mqsaharan, Marco1971
Offline rsjsouza
  • Eternally curious
« Reply #14 on: May 17, 2018, 05:45:37 pm »
Excellent review; I was always curious about this meter and this certainly was very informative. Thank you!
    • Tests
Re: Technical multimeter review and tear-down, more than 50
« Reply #15 on: June 04, 2018, 01:48:40 pm »
Now the list has more than 50 multimeter reviews.
The following users thanked this post: rsjsouza
    • Tests
Re: Technical multimeter review and tear-down, more than 60
« Reply #16 on: August 01, 2018, 03:36:42 pm »
The list has passed 60 DMM reviews included the EEVBlog 121GW
Online coromonadalix
« Reply #17 on: August 02, 2018, 02:18:33 am »
nice work
Offline mqsaharan
  • Country: pk
« Reply #18 on: August 02, 2018, 04:57:55 pm »
Hi HKJ
Thank you very much for accepting my request and reviewing your Fluke 289. I appreciate your efforts.
I was more interested in the working details of this meter that you presented very nicely.
In your reviews, Summary table is very useful to see most of the specifications at a glance.
Would you kindly tell me what is the difference between True RMS and True AC as there is also a third box AC+DC? Also what does Fast means or refers to.
If you would like you can add "On/Off Button" to the empty box. There are only a few handheld meters left that have a dedicated On/Off button.
Regards,
Qasim.
    • Tests
« Reply #19 on: August 02, 2018, 05:24:46 pm »
With True AC means the meter can handle a large DC or AC while measuring the opposite type
The AC+DC means the meter can show the RMS sum of AC+DC.
This means the meter has a mode with fast updates and usual less resolution (This is mostly for bench meters).
You can find a explanation of all the items and a bit about how I test here: https://lygte-info.dk/info/DMMinfo.html
There a some parameters that I do not really see as significant, the on/off button is one of them, (non)latched continuity is another, that is the reason they are missing in the schema.
Offline mqsaharan
  • Country: pk
« Reply #20 on: August 14, 2018, 10:10:20 pm »
Hi HKJ,
I was reading your review of HIOKI DT4282. There seems to be a mistake on 2nd line under Measurements, Volt and frequency. The line reads:
"At 100mVrms VAC frequency input range can be stretched to 500MHz that is maximum for meter."
The upper limit I think is 500kHz and not 500MHz.
In your Brymen BM869s review, may I request for a little more explanation regarding point/line number 12 under Measurements, Volt and frequency. It reads:
"Large AC values on DC ranges will prevent the meter from showing a value, except if dual display AC and DC is selected."
Could you please mention how large an AC value on DC range prevent the meter from showing a value at all. Also is the behaviour same for line frequency 50/60Hz and lower/higher frequencies.
And for the line number 15 which reads:
"The DCV & DCmV range has two paths: Directly DC volt and True-RMS volt, they will not show exactly the same value. The 500000 read out the direct DC mode."
Could you please mention the difference between both values. Also which mode shows (closer to) the actual value.
The same is true for BM525s review.
Regards,
Qasim.
    • Tests
« Reply #21 on: August 15, 2018, 07:42:04 am »
Hi HKJ,
Thanks, it is fixed
I uses about 630VDC and 230VAC, in the article I link at the bottom of the review I do explain about the test.
My tests at mains voltage are mostly done at 50Hz because I live in 50Hz country (only exception is usb chargers that is tested 120VAC 60Hz).
There is no mystery in this, the DC range do not need rectification, but the AC+DC range uses the true-RMS converter and that means the meter has a worse specification for this. The actual difference is about 6 count on 1 volt DC on my BM869s
Offline mqsaharan
  • Country: pk
« Reply #22 on: August 15, 2018, 02:52:07 pm »
Thanks for the clarification.
I did visit the "How Do I Review a DMM" page but I didn't read it thoroughly, gave it more of a cursory look.
The reason I asked the question was I thought you have some variable source for AC and DC and you have been feeding the meter with different voltage levels when you found that anomaly.
I guess these meters work all right at low levels otherwise many users have complained about it.
I guess nothing to worry about here too. The meters seem within specifications.
My suggestion is to please do mention this difference of 6 counts on the review pages, makes it more clear.
Regards,
Qasim.
    • Tests
« Reply #23 on: August 15, 2018, 02:56:57 pm »
I have a AC generator that can deliver variable AC voltage, but for that test I only use a fixed voltage. When I test a LowZ range I sweep with the generator.
    • Tests
Re: Technical multimeter review and tear-down, more than 70
« Reply #24 on: October 03, 2018, 03:24:01 pm »
I keep adding multimeter reviews and are now past 70.
Offline rsjsouza
  • Eternally curious
« Reply #25 on: October 03, 2018, 08:48:19 pm »
That is a great page; thanks for doing these reviews!
    • Tests
Re: Technical multimeter review and tear-down, more than 80
« Reply #26 on: December 13, 2018, 03:31:54 pm »
The list of reviewed meters has passed 80.
There is links to a couple of articles about using multimeters at the bottom of the list.
    • Tests
Re: Technical multimeter review and tear-down, more than 100
« Reply #27 on: April 24, 2019, 03:30:31 pm »
The number of reviewed meters has just reached 100.
The following users thanked this post: rsjsouza, Fungus, gabeeg
Offline kayvee
« Reply #28 on: April 24, 2019, 06:22:09 pm »
A lot of hard work went into this, thanks for your efforts, it's a useful resource.
Offline Cnoob
« Reply #29 on: April 24, 2019, 07:09:52 pm »
Very impressed with your hard work.
One thing I noticed is the Hioki DT4282 best dc accuracy.
My manual states.
6V and 60V range is +-0.25% rdg +- 2dgt at 11Mohm and 10.3Mohm respectively.
You give the 600mV range which is +-0.025% rdg. +-5dgt at 1Gohm or more same input impedance as 60mV range.
As for the 400 memory locations I have only used a maximum of 4.
« Last Edit: April 24, 2019, 07:18:16 pm by Cnoob »
    • Tests
« Reply #30 on: April 24, 2019, 07:20:52 pm »
My manual states.
Thanks, I have fixed it.
    • Tests
Re: Technical multimeter review and tear-down, more than 110
« Reply #31 on: August 08, 2019, 02:45:08 pm »
I do still add meters to this list and have now reached 110 multimeter reviews.
The following users thanked this post: rsjsouza, 001, BillB
Offline rsjsouza
  • Eternally curious
« Reply #32 on: August 08, 2019, 06:14:18 pm »
HKJ, let me put here that I visit your page whenever I want to take a look at a meter specs, or suggest a model to someone. The information you present there is concise and very well put together.
Thanks for all the effort.
Offline 2N3055
  • Country: hr
« Reply #33 on: August 08, 2019, 08:24:10 pm »
I agree. It is excellent work and lot of effort. Thanks!
Offline Jorge_dPO
« Reply #34 on: December 01, 2019, 04:50:49 pm »
Witch multimeter would you recommend for a starting/hobby use? The Owon B41T+, the aneng AN870 or the uni-t it 139e.
I don't know witch one will be better.
    • Tests
« Reply #35 on: December 01, 2019, 05:29:10 pm »
I will suggest looking on my list of good meters:
https://lygte-info.dk/info/DMMReviewsGood.html
The list is automatic build based on some parameters, i.e. you must also check the reviews.
If you want a really good meter, look at Brymen. They are considerable more expensive than Aneng, but you get a much more robust and safer meter for the price.
The following users thanked this post: Marco1971, Feliciano, Jorge_dPO
Offline Fungus
« Reply #36 on: December 01, 2019, 06:05:21 pm »
Aneng AN870.
The following users thanked this post: Jorge_dPO
Offline Jorge_dPO
« Reply #37 on: December 01, 2019, 11:45:45 pm »
What do you think about the Brymen BM252s?
Offline Jorge_dPO
« Reply #38 on: December 01, 2019, 11:47:13 pm »
Can I ask why the AN870?
    • Tests
« Reply #39 on: December 02, 2019, 06:06:27 am »
It look like a decent meter, but it is missing backlight and max/min.
Offline Jorge_dPO
« Reply #40 on: December 02, 2019, 09:28:08 am »
And the BM257s?
Offline Fungus
« Reply #41 on: December 02, 2019, 10:28:27 am »
Because they're awesome and cheap and if it's your first multimeter then you don't know exactly what you need so best not to buy an expensive one, yet.
And ... you need more than one multimeter so this will still be useful after you buy an expensive one.
PS: You don't say what your main job requirement is so you might not get the best advice.
« Last Edit: December 02, 2019, 10:30:13 am by Fungus »
    • Tests
« Reply #42 on: December 02, 2019, 10:48:00 am »
And the BM257s?
It is the top meter in the 25x series and have a good selection of ranges. It is also well protected and Brymen meters can last a long time.
A few comments to the specifications:
It will warn you if probes are in current ranges when selecting voltage measurement, this is a nice safety.
If you want to check mains outlets or voltages, the low-Z function can be very useful.
The computer interface is extra, if you want to log measurement over a couple of hours this is a nice extra.
The meter do not have average (You need fairly high end meters for that), it can be useful for measure average current consumption on devices where the current varies.
The frequency only goes to one 1MHz, I will say that is more than enough, a multimeter is not for measuring RF.
It is missing duty-cycle (The best meters for measuring duty-cycle (PWM) is usually the cheap meters without much input protection).
The capacity range is limited to 3000uF, this means it cannot test large electrolytic capacitors, usually this is not very important.
Offline Jorge_dPO
« Reply #43 on: December 02, 2019, 11:45:02 am »
I just like to play with electronics and sometimes make some electric repairs in the house and my motorcycle, so it isn't nothing serius, thats why i was thinking about the 139E, because it have a more or less good protection for main voltage.
Offline Jorge_dPO
« Reply #44 on: December 02, 2019, 11:51:14 am »
Thanks for the info, i probably will buy the aneng 870 or de ut139e, and then start saving money for a Brymen, maybe the 829s?
By the way, the AC + DC function, when can it be used? It is useful?
    • Tests
« Reply #45 on: December 02, 2019, 11:58:55 am »
It will measure the total voltage. Standard for multimeters is to filter and only show either the DC or the AC part, the AC+DC combines the two into a single RMS value. In some cases a function that shows both AC and DC values simultaneous is more useful.
Neither is required, you can always do two measurement and do the match yourself (It is not a simple addition).
Offline LeonR
  • Country: br
  • PC hardware enthusiast
« Reply #46 on: December 03, 2019, 03:38:18 am »
First and foremost I'd like to thank you for doing those reviews. It's pretty nice to have a detailed look on that variety of makers and models.
As a suggestion, have you thought about listing models that are based on a same platform?
    • Tests
« Reply #47 on: December 03, 2019, 05:09:06 am »
No, it is difficult to see if two meters are the same without testing them.
Offline LeonR
  • Country: br
« Reply #48 on: December 03, 2019, 03:06:13 pm »
I meant for the ones you've tested, like the HY-19E and Zeast 282.
    • Tests
« Reply #49 on: December 03, 2019, 04:23:29 pm »
I cannot remember all the meters, this means it would require some extra work to check the specifications and tear-down photos and I do not see it as a very interesting detail.
Offline geogeo
« Reply #50 on: December 04, 2019, 01:31:26 am »
I really like your review page. It's great that you keep the format essentially the same for all reviews, that makes it very easy to compare 2 different meters.
The following users thanked this post: Fungus
Offline Analog4
« Reply #51 on: February 14, 2021, 10:46:52 pm »
This is a great multimeter review resource. Thank you very much.
I had been looking at the Brymen BM869s, but it seems the Greenlee DM-860A is generally more available in the USA (maybe easier to get proper warranty support in the USA?).
https://www.greenlee.com/us/en/dmm-500k-counts-dm-860a-calib-dm-860a-c?w=2&c=167&b=86&t=6&r=30&p=1&lat=37.362107&lng=-121.982035&l=4&v=c
https://www.tme.com/us/en-us/details/bm869/portable-digital-multimeters/brymen/bm869s/?brutto=1
From the reviews linked from this thread, it appears that the MASTECH MS8218 quality and design may not be as solid as the Brymen or Greenlee?
I guess one could buy the Brymen BM869s here ($270?): https://www.welectron.com/Brymen-BM869s-Multimeter_1  But then the warranty might be an issue
« Last Edit: February 14, 2021, 11:05:08 pm by Analog4 »
    • Tests
« Reply #52 on: February 15, 2021, 05:57:55 am »
Mastech is a typical Chinese multimeter, i.e. quality and safety is lower.
It is very seldom you need warranty on a multimeter, but if you want warranty, go for Greenlee, it is the same meter.
Offline J-R
« Reply #53 on: February 15, 2021, 09:54:27 am »
Welectron BM-869s Edition+ (adds Brymen case) is $225 delivered with the 5% EEVblog discount code.
Greenlee version is $313+shipping at https://www.tequipment.net/Greenlee/DM-860A/Multimeters/?v=0
Offline Fungus
« Reply #54 on: February 15, 2021, 11:15:28 am »
Greenlee is the Brymen distributor in the USA but they have a big markup and a horrible color (IMHO).
You're very unlikely to ever need it, ie. It's certainly less than $100 of risk on your part.
(if it's DOA then I don't think Welectron will let you down)
