Author Topic: tek 453 x or y issues?  (Read 591 times)
Offline m3vuvTopic starter
« on: August 22, 2018, 09:31:40 pm »
hi all,ive a tek 453,im trying to use an octopuss with it,when i first put it in xy mode it displays a dot as it should do,then shorting the octopuss probes together i get a verticle line as expected then after a second or 2 it reverts back to just a dot on the display,when i tap the scope i can get the trace back to normal for another couple of seconds,would the problem be with the x or y circuit?,it only plays up in xy mode and fine otherwise,i dare say its a socketed transistor dirty but not sure where to start looking,cheers m3vuv 73
